Hawk HP Plus Pad Squeal...Does it get better?????
  • Braap
    • Feb 2011
    • 75
    Just installed a set of HP Plus pads on my car and the squealing is literally unbearable. I mean I knew what I was getting into with aggressive pads but it's to the point where I'm embarrassed to drive my car. Anybody know if these get any quieter with time? Suggestions? :(
  • akorcovelos
    • Dec 2006
    • 1149
    mine squeal a bit, but not that bad.
    2012 MCSCC/NSSCC CP class champ
    HSAX Instructor
    • bmwguy325is
      • May 2011
      • 1263
      All depends on how well you did your brake job. Did you use the backing plates? They help with squeal a lil bit. When I ran them they only made noise under light breaking and then it tappered off.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Cronopoulos
        • Jul 2011
        • 2187
        Mine squeal like a bitch but i care not.
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • CoreyZ
          • 384
          How did you bed in the pads?
          • nrubenstein
            • 3148
            They squeal like pigs unless you use a metric crap ton of brake goop. That's just how they are.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • acolella76
              • 2950
              -Alex
                HP+ pads are just gonna squeal unless they are fully hot, which probably isn't going to happen on the street. Interestingly, I never hear squeal from the PFC-01 race pads I use on my Spec E30 unless they are hot and lightly used.
                • bastianshaw
                  • Jan 2007
                  • 2210
                  triple digit speeds then HAMMER the brakes
                  • Braap
                    • Feb 2011
                    • 75
                    Thanks for all the help...I guess they essentially will be getting better. I don't know anything about bedding in pads...so not sure what i could do there. And Castro's installed them so I have full faith that the install is not to blame. : )
                    Does anyone know how the HP + compare to HPS pads, noise/performance wise?
                    • 110stx
                      • Sep 2011
                      • 253
                      HPS suck.
                      My HP+s don't squeal until they start to get warm.
                      My buddy's e30///M3 with HP+s squealed like a stuck pig everytime you brushed the brake pedal. *shrug*
                      It helps to lube the contact/slide points on the caliper and the pad backings to dampen vibrations that cause the squealing.
                      STX e30
                      No. 10/110 STX: 1989 325i
                      DD: 1991 318is slicktop
                      SHAZAM, GOMER, LOOK AHEAD.
                      • nrubenstein
                        • 3148
                        Why? It's NOT NORMAL to use the crap load of brake goop that the HP+ requires in order to be tolerable. In fact, the normal practice is to discourage the use of goop because almost all modern brake pads have no need for it and it can gum things up.
                        Unless you specifically requested it, I would assume that they used none whatsoever and that your pads will stay loud as shit until you wear them out. (I have had multiple sets and they don't get quieter, the only real difference is that E30 brakes are more prone to squealing than E36 or E46 in my experience. Either way, goop was mandatory.)
                        • cbouchez
                          • May 2007
                          • 2789
                          That is the way mine are...
                          Follow my IG @bouchezphotography
                          • rwh11385
                            lance_entities
                            • 18403
                            No. Sometimes deafening to cars next to me at the stoplight.
                            Even my performance ceramics from Hawk that should be quiet sometimes squeal in parking garages or other places with light slow low levels of brake use.
                            Brake hard and fast. Why? Because Racecar.
                            I believe the harder clamping allows for less vibration... Which is what goop tries to prevent IIRC
