Control Arm Bushings?
  • Threehz
    • 1480
    So the two bushings on both my control arms are shot but the control arms appear fine. It's been said that replacing those bushings and not the control arms is possible but I cannot find the bushings anywhere.
    BAV auto appears to have what may be those bushings but I don't know for sure.
    In case anyone is lost it's the two bushings in the picture
    Anyone know where to get these?
    Different strokes for different folks.
  • ChefSkinny
    • 213
    those are called Ball joints. By the time you buy them, and pay a shop to press them in properly, they will cost you more than new control arms. Lemfoerder sell for <$100 per side, with new ball-joints.
    • Threehz
      • 1480
      Ah this makes sense now, thank you.
      That sucks.
      • Killacortes
        • 1937
        Control arm bushing is the bottom of the picture. It slides onto the control arm. Yould replace those too while your at it
        r3v does not fuck around. First you get banned, then they shoot you
        • Threehz
          • 1480
          Yeah, those still look good, PO replaced with M3 offset bushings so they are newer, but I'll feel em up and see
            The control arms don't wear, but the ball joints do. Which is why you replace the control arms. In the general case, when replacing the control arms you also need to replace the tie rods, upper strut bearings, and control arm bushings.
            • Threehz
              • 1480
              Well as much as I hate to hear about more parts I should replace, thank you for the infos!
              • Threehz
                • 1480
                Would there be any reason to get the M3 offset c-arm bushings instead of the regular?
                Would there be any problems doing this?
                • jrobie79
                  • Mar 2006
                  • 2525
                  offset bushings = more caster for higher speed stability, it will make it a little harder to turn at low speeds
                  1991 318i ---- 308K - retired
                  • Threehz
                    • 1480
                    I see, thanks for the knowledge sir.
