Rear Swing arm bushing replacement
  • E30DriverGS
    • 29
    Gonna replace the swing arm bushings with new factory rubber on my '91 318iS E30. Any blogs about "how to" for best practices to r&r bushings. Got everything apart, just looking for hints for getting old out and new in. Lube to use, silicone grease DowCorning 4? I have a hyd. press so power is not aN issue.
    Any suggestions are appreciated. Geo
  • 2quikmotorwerks
    • Oct 2006
    • 154
    If you look in the diy section there is a writeup, its pretty straight forward and with you having a press even more easier
    • E30DriverGS
      • 29
      Thx will give it a look. Geo
      • KenC
        King of Kegstands
        • 14396
        You'll need to make a tool to get them in and out. A press doesn't help. Basically a pipe, washers and a threaded rod. There's a pic in my user gallery of ours I think. It was about $10 in stuff from home depot.
        Originally posted by Gruelius
        • FredK
          • 14763
          You can torch them out and use a press to press them back in. I use turpentine to wet the exterior of the stock rubber bushing when pressing them back in.
            For about $30 you can get a trailing arm bushing tool from AKG. It works a bit better than what you can cobble up with threaded rod and pipe fittings.
            A hint that makes getting the old bushings out easier is use a hack saw to cut away the lip of the bushing on the outboard side. That will expose the metal of the trailing arm and give the tool a place to seat.
            • StereoInstaller1
              GAS
              • 22679
              Use Dawn dishwashing soap as a lube to assemble anything rubber, from subframe bushings to antenna grommets. Trust me on this, you will be glad you did.
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • 2quikmotorwerks
                • Oct 2006
                • 154
                ^^^^^^^ this
                • dogsbark26
                  • Nov 2008
                  • 533
                  Really. I would have thought glycerin rather than Dawn. Don't need much.
                  • Thehemiman
                    • Apr 2009
                    • 533
                    I did the same and it worked great for me. Punched the old ones out with a hammer/metal rod once they got hot enough and used dawn/a press to get the new ones in.
                    1988 325i Vert
                    1991 318is Slicktop
