318i upgrades
  • ruizl300
    • Apr 2012
    • 67
    318i upgrades
    I posted this in my progress thread and didnt get any feedback since not many are viewing the M10 subforum. Maybe I can get better feed back here.
    Ok, so I have a list of things I will need to upgrade to caliper/rotors for all 4 wheels.
    Front of Car:
    Take he whole strut assembly (IDK if that is what its called) along with
    Hub/calipers/rotors/pads
    pretty much looks like this:
    Brake Lines:
    1: Take the hand brake lines
    2: Take the Line from the T to the Calipers
    Questions:
    1. Will I need to take a brake booster (Non-ABS) from one of the 325s?
    2. Will the master cylinder need replacing or is the stock one fine?
    3. Will I need the check valve on the brake line between the master cylinder and the "T"?
    Rear of Car:
    1: Take upper spring seat
    2: Take Coil Spring
    3: Take shock obsorber
    4: Stabilizer Bar (Is the one on the 6cyl cars better/bigger)
    5: Hub/Caliper/Rotor/Pads
    6: Trailing Arm
    A. Is there anything I am missing?
    B. Is there anything not necessary (Ex. Brake booster, ect)?
    C. What parts are better to just buy new? (Ex. pads, rotors, ect)?
    I appreciate all the help. I know that I am writing a lot. But as someone who is learning I appreciate post like this. The details help a lot of newbees and sometimes people can come off kind of harsh when a newbee ask questions.
    Once again thanks.
  • ruizl300
    • Apr 2012
    • 67
    Anyone?
    • mit7059
      • Apr 2012
      • 19
      I'm looking to do pretty much the exact same thing on my 318. From my understanding you don't need to replace the master cylinder brake booster etc unless you want to retrofit abs. I do believe you need to replace the brake lines on the rear brakes to the t and you also need to replace the parking brake cable. Everything should bolt right up, it's supposed to be a simple swap
      • ruizl300
        • Apr 2012
        • 67
        OK, cool. Do you know if the stabilizer bar is diff/larger on any of the 325s compared to the 318i.
        • E30_Pare
          • 7801
          Just need the handbrake cable that is all. 318 doesn't come with a rear sway bar. Some people argue against it. Personally I don't think l the e30 needs one. Just pull he front sway from a cabrio if u want an upgrade. Don't see why u would need much of what u listed. Just use the stock brake booster also. No need to upgrade.
          DREWLIENTE
          1$ PShops PM me
          • jeffnhiscars
            • Jun 2011
            • 6010
            M10 318's came w rear drums so if you are doing a drum>disc conversion you have to swap trailing arms & ebrake cables.
            Alice the Time Capsule
            • E30_Pare
              • 7801
              If I were to upgrade I would just pull a complete rear end with LSD. Might as well go all the way
              DREWLIENTE
              1$ PShops PM me
              • ruizl300
                • Apr 2012
                • 67
                Yes, Ive been doing more reading and things are pointing me in that direction.
                • einstein57
                  • Jun 2007
                  • 10780
                  Is the MC the same size as a 325e? Real oem says 19,05/20,64MM for the 318i and 20.64 for the 325e. Is it a split MC or did they have 2 different models? I pulled the booster out already because i'm painting the engine bay. I have a spare m20 booster that i'm going to be using since i'm doing an m20 swap and the vacuum line port is on the opposite side.
                  www.gecoils.com
                  • E30_Pare
                    • 7801
                    Nigel I don't think theyre the same size. Maybe a tad smaller cant be sure never had them side by side, but most people tend not to upgrade since the stock mc seems to be adequate
                    DREWLIENTE
                    1$ PShops PM me
                    • E30_Pare
                      • 7801
                      Jean had some pretty detailed info on his brake swap. Was in his build thread iir
                      DREWLIENTE
                      1$ PShops PM me
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        You want more understeer? Get the rear sway and leave the stock front one. It makes the car perfectly neutral and amazing.
                        • Holland
                          • Nov 2008
                          • 7202
                          I have a cabrio bar and an m3 rear and my 318 is super neutral.
                          Originally posted by DEV0 E30
                          • Jaxx_
                            • Dec 2009
                            • 1880
                            Yeah, but you have a rear bar. Who would run a cab front with no rear?
                            • Holland
                              • Nov 2008
                              • 7202
                              True, I agree with you on that point.
