Vorshlag vs. Ground Control (camber plates)
  • ethirtydavid
    • Jan 2008
    • 2331
    What do you guys know about the pros and cons between Vorshlag and Ground Control for camber plates?
    Ground control race -329$
    Vorshlag -419$
    They both are quick adjustable for street/track settings- and they are both adaptable for all spring types.
    I'll be running offset CABs with IE3 springs, adjustable rear subframe.
    thoughts? experiences?
    Links to both:
    *edit, oops thought I was in springs/shocks section- mods can move if ya like.
    I don't know of any advantage of one over the other if we are talking GC (Spec E30) Race plates.
    • Holland
      • Nov 2008
      • 7212
      My GC spec plates look almost identical to that Vorschlag plate.
      Originally posted by DEV0 E30
      • ForcedFirebird
        • Feb 2007
        • 8300
        Suppose it's the difference between price if they serve the same function with equal strength/longevity.
        john@m20guru.com
        Links:
        • ethirtydavid
          • Jan 2008
          • 2331
          ^ this is what I am trying to prove or disprove. anyone ever use them?
          • bmwguy325is
            • May 2011
            • 1263
            I have the vorshlag plates I really like them. GC makes a kit for which you can get more caster.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • lambo
              Captain Scene Points
              • 10953
              +1
              Also, OP, you mentioned the GC Race plates, but you pictured (I believe) the touring plates...
              These are the race ones:
              • burkey001
                • Feb 2011
                • 608
                I have Vorshlag on my AST 4210's on my E30 and GC Race on M Coupe.
                Both are super nice pieces, can't say a bad thing about either of them. Vorshlag may run a slightly larger spherical bearing, marginal.
                I would buy it as a package. I.e. you're going to get GC coils, get GC plates. If AST, get Vorshlag.
                Or buy the cheaper ones, both are great.
                88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                • ethirtydavid
                  • Jan 2008
                  • 2331
                  Ah, you're right, I originally meant to compare the touring GC vs Vors.
                  I suppose GC race is a better comparison, but only 10 dollars more than their touring plates.. I expect the race is the GC plate with greater caster adjustability
                  Theres another question, GC touring vs GC race for a daily with autox time.
                  Is there a disadvantage to using GC race plates(ie. too much caster)?
                  • ethirtydavid
                    • Jan 2008
                    • 2331
                    Oh I see race plates GC dont allow for stock diameter spring type..
                    Seems like the touring plates may be the best match for me. The money I save is about that of the alignment also.
                    I'll keep looking into it a bit. Good feedback so far, seems like these plates are pretty competitive with each other
                    • M-technik-3
                      • 18946
                      Touring style don't rattle either. Race plates make noise street driving.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        Originally posted by ethirtydavid
                        ..I expect the race is the GC plate with greater caster adjustability
                        GC makes a couple different camber plates. But yes on has a great deal of caster adjustment. I look at it this way the more adjustable the better.
                        My Vorshlag plates were noisy until I greased them. Now quiet as all can be.
                        • ethirtydavid
                          • Jan 2008
                          • 2331
                          • seatown88
                            • 331
                            I am very happy with my ground control plates. I was really impressed by the quality of them and their ease of adjustment.
                            I always hear good things about the Vorshlag pieces too...all depends on how much you want to spend
                            • Holland
                              • Nov 2008
                              • 7212
                              Spec plates should use your stock upper spring hat with no issues...
                              My spec plates make no noise and I've been daily driving them for at least 2 years now.
