You have all the info need on this second page of the thread. Remove relays, jump relay NO contacts (connect 87 and 30 together) with wires and jump the valves (1, 3, 5 to the ground).
I had same issue a year ago when I swapped mc/booster and had the lines disconnected a few months, couldn't apply force to lock wheels even on gravel. I activated pump and valves by jumping wires, multiple times each and then bled and I was ok. I know the valves should be open by default, but they weren't. No issues since.
