Control Arm Bushing BandAid
  • WhyNot
    • May 2012
    • 363
    hi all,
    my front control arm bushings are bad and the arms are floating all over the place.
    i need new bushing.
    but i did a quick bandaid repair that helps until a correct fix is had.
    i filled the empty spaces, which were towards the center [they are standard e30 bushings not m3 but they were kinda in the m3 position] with some 9/16" x 2 1/4" long bolts and locking nuts.
    i just banged them in from the front towards the back and used locknuts.
    took about 20 minutes and cost about $10.
    it made a major improvement, plus now they are 'eccentric' like m3.
    i'm not real fast, and i'm not real slow, i'm half-fast.
    hope it helps someone.
    keywords - temporary cheap easy wandering loose oral sex floating vague
    whynot
    Originally posted by der affe
    What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
    Originally posted by navid41691
    And no, I use lotion so I don't have to worry about skin irritation.
    '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
  • Boise
    • 212
    Originally posted by WhyNot
    hi all,
    whynot
    Ummm, what???
    • Vivek
      attention whore/retard/bitch
      • 6167
      Wait so you put bolts through the space in your lollipops to compensate for worn bushings?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • WhyNot
        • May 2012
        • 363
        yes that is exactly what i said and exactly what i did.
        • WhyNot
          • May 2012
          • 363
          Originally posted by Boise
          Ummm, what???
          i figured everytime i search for something nonsexual a link for oral sex pops up so now someone searching for oral sex can get to this post.
          • george graves
            • 20003
            Originally posted by Matt-B
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Once, I had an engine with low compression, so I pulled the sparkplugs and dumped 1/4 cup of MDF sawdust into each cylinder. I figured if I used metal shavings from the brake lathe catch tray, I might get it stuck inbetween the tip and electrodes on the plugs. It worked really well, so I just kept driving.
              Then the automatic transmission started slipping, so I put a 1/2 cup of Quaker Old Fashioned Oatmeal down the dipstick to make the clutches engage better. Still going strong.
                • 37833
                This is fake, it has to be. Nobody is this stupid.
                Grover Beach, California
                BimmerHeads.com
                • Wh33lhop
                  • 11705
                  lol, here we go.
                  paint sucks
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    It's nice to see that the real farbin is still alive and well
                    • WhyNot
                      • May 2012
                      • 363
                      banannas in the diff work even on lsd.
                      valve adjustment is time consuming and tricky.
                      lowes has the 'pink panther' insulation in 12" widths.
                      there is enough to do several cars.
                      just remove the valve cover and cut it to length.
                      i am a perfectionist so i doubled it up.
                      wow what a difference.
                      no more valve noise.
                      it took about 10 minutes and cost less than $5 [if you do 8 or more cars]
                      whats great is it isnt just for e30's!!!
                      works in all motors and all motor noises.
                      i'm going to put new banannas [they do wear out you know] in the diff and add some insulation to get rid of the bearing noise.
                      i would post pics but i cant do much with the polariod shots.
                      • SpecM
                        • Oct 2005
                        • 4531
                        Oh thank God it was a joke
                        Sent from my Vortex
                        1989 cirrisblau-metallic 325i
