so my wife's e36 front brake lines are due for replacement so i was looking up some ss brake line on google and found some infos that ss line are not as good as they're advertised. what does r3vs thinks about this?
stock rubber vs ss brake line
I've seen a fair number of SS line failures. Usually the failure is the line pulling out of the end fitting. I've never seen that type of failure with OE lines. That kind of makes sense if you consider the materials involved. The OE lines are more resilient and the crimp sleeves are going to have a better grip on the lines.
Like most everyone else, I put SS lines on my race car, though I did use good (i.e., expensive ones). I can't tell any difference in brake feel between SS & OE lines and this year, when it is time to change the lines and rebuild the calipers, I'm going back to OE lines.The car makes it possible, but the driver makes it happen.
Originally posted by jlevie View PostI've seen a fair number of SS line failures. Usually the failure is the line pulling out of the end fitting. I've never seen that type of failure with OE lines. That kind of makes sense if you consider the materials involved. The OE lines are more resilient and the crimp sleeves are going to have a better grip on the lines.
Like most everyone else, I put SS lines on my race car, though I did use good (i.e., expensive ones). I can't tell any difference in brake feel between SS & OE lines and this year, when it is time to change the lines and rebuild the calipers, I'm going back to OE lines.Old and improved:
