Quick Question: Rear Subframe Stud Torque Spec
  • bubbajan21
    • 1962
    I'm putting back together my rear subframe after new bushings and IE Camber and Toe Kit and I can't find a spec for what the rear bolts (the ones that pass through the bushings) should be torqued to. I've found this link but I don't know if they should be torqued to 30 or 56 ft-lbs.
    Find information, resources and relevant links for e30world.com. This domain may be for sale.
    Thanks in advance!
    I don't have a reference handy, but those sound low. Something around 80ft-lb seems more reasonable.
    • mRodiek
      • 597
      As hard as they go, mine have been great for 6months+ now
      Originally posted by e30lov
      sweet a mk4 jetta, haven't seen one of them for about 14 seconds
      Adventures of an E30
      • Boise
        • 212
        Bentley has the same numbers
        M10 is 30 ft-lbs
        M12 is 56 ft-lbs
        So if its a 10mm bolt (width) its 30 ft-lbs, 12mm bolt is 56.
        I did mine last winter at 56 ft-lbs and the subframe hasn't come off...yet. I figure the engineers at BMW know what they are doing.
        • RobertC
          • Dec 2010
          • 127
          Personal Torque Values
          Subframe Pins: 80ft lbs (95ft lbs for 75D or solid bushings)
          Diff Carrier Bolt: 65ft lbs
          Trailing Arm Bolts: 65ft lbs
          PS: Rear subframe studs are 14mm.
          www.facebook.com/E30motorwerks
          • Boise
            • 212
            Interesting, I just looked at RealOEM and they have a 14mm nut to go with the bolt, so I wonder if those Bentley torque specs are for something else.
            • bubbajan21
              • 1962
              Hmmm, so it looks like listed spec if 56 but everyone runs 80??
                • 37833
                I tighten mine until they're tight.
                Grover Beach, California
                BimmerHeads.com
                • Aluke123
                  • Aug 2011
                  • 76
                  M10 is 30 ft-lbs
                  M12 is 56 ft-lbs
                  Pretty sure those are the torque specs for the front subframe bolts, not the rear ones.
