Too much?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Too much?
    that pulled the body part didnt it...
  • Exodus_2pt0
    • 5943
    Trying to replace a subframe at work after the lady hit a curb at speed. It's in a vert to boot. Seeing this makes me want to vomit.
    If your asking if you should replace that bushing, yes.
    No E30 Club
    • GunMetalGrey
      • Dec 2010
      • 1499
      I am replacing it, but is that plate supposed to be there? Isn't that part supposed to stay in the body?
        • 37832
        If I am seeing things right that's part of the bushing. The bushing has a thick metal sleeve going through it and the wide washer goes on top. The part that stays in the body is the stud.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          That "plate" is a washer. It is not a part of the car body.
          • Exodus_2pt0
            • 5943
            ^ What they said, I have one sitting on the floor of my shop right now. Totally normal
            No E30 Club
            • Massimo
              • Jan 2008
              • 3207
              Wow that is a fucked subframe bush, looks like it has melted.
              • Roysneon
                • 4505
                Nothing bad happened, you just got lucky and the whole aluminum sleeve came out with the bushing. On my car both of them broke off and stayed in the body of the car and I had to bust them up with a punch to get them out. If the other one doesn't look like that then check the mounting point to see if there is part of the aluminum stuck in there.
                Originally posted by mbonanni
                I am a pursit now.
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  I figured it out, and got the poly in without fault!
                  It really is not that hard to do the subframe bushings, hardest part is getting the old ones out lol!
