Bushings?
  • VitaminJ
    • Nov 2005
    • 63
    Bushings?
    What bushings are recommended to be replaced for aging E30s?? a 91 318is to be specific :)
    -J
  • DaN
    • 1265
    Front control arm bushings, rear trailing arm and subframe, rear shock mounts, diff cover bushing. Engine and trans mounts. I wouldn't change them unless they needed it. Check em first.
      • 34844
      • MarkH
        • Jun 2005
        • 65
        I changed the following on my car:
        Front Contral Arm Bushings
        Front sway bar bushings
        Front Strut Mounts
        Rear Subframe Bushings
        Rear Trailing Arm Bushings
        Rear Shock Mounts
        I would also recommend you look at the ball joints on the front control arms, and tie rods as these are probably in need of replacement if they have not already been replaced. The rear subframe a pain in the butt to replace, but worth the effort as they make a huge difference in the handling of the car. If you do the rear subframe bushings, replace the brake lines with stainless steel lines. This is one upgrade you will not regret.
