Any treehouse racing control arm bracket reviews?
  • noid
    • 1536
    Thinking of picking up a set of treehouse racing front control arm brackets.
    For those who have them, how do you like them and would you buy them again?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • F34R
    sLaughter
    • 12376
    I have them and love them, worth every penny. I would buy them again for any future e30 I own. My brother and sister both own them on their e30s.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • tttoon
      • 275
      I have them and I love them. Watch out with the caster though, since they push the wheels even further than the M3 CABs. My car ended up with 10 deg of caster, and the rear of the valence needed persuading.
      • F34R
        sLaughter
        • 12376
        GC race plates solves that^
        Current cars:
        ~ '87 535
        ~ '06 X5 4.8is
        • giantkeeper
          • Aug 2009
          • 1416
          I've run them on e30, e36 m3, and e46 m3. Best product of the sort on the market!
          Always Always go for the reach around if there is an option
          • 85e325
            • May 2011
            • 551
            A good friend of mine is the lead mechanic down at treehouse (now bimmers usa) and I got to drive his '88 stroker before and after he installed a set and the difference is amazing!! I have E36 m3 bushings on mine and I cant wait to have the cash to pick up a set. deffinitly a great buy
            Justin Angelli
            1985 325e Gazellenbiege
            • smerfs
              • 319
              +1
              Just installed these. Super easy and they function very well.
              320I - under construction
              • noid
                • 1536
                Shouldn't be a problem with stock weaves and stock sized tires?
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  They are awesome for handling, but I am running into the problem mention above. I am not sure where exactly it is rubbing, but it is.
                  16x8 225/45/16 +20
                  For reference.
                  • CabbE30
                    • Aug 2009
                    • 2358
                    We're talking about eyeball arms right?
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      How much better are Treehouse brackets over AKG race offset CABs? Is the extra caster noticeable?
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • F34R
                        sLaughter
                        • 12376
                        AKG ones are poop, I would never buy those. The THR ones are a fixed position bushing. And 10 degrees is not bad at all, I fixed it with the GC race plates I am running. Granted they are a bit annoying to get in place, I use a rubber hammer to pop them in.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • Vivek
                          • 6167
                          Ehh, I already have AKG's so I'm sticking with those. They feel pretty damn stiff to me, but I'm sure that the Treehouses would be better. Whatever, it's just a vert.
                          • noid
                            • 1536
                            I put new lemforder control arms on a couple months ago, and recall the 'stub' of the control arm that the bushing goes over to have spiral groves into it rather then being smooth. I hope this wont effect the treehouse eyeballs?
                            For illustration:
                            • ZinnoBerrotEta
                              • Dec 2010
                              • 240
                              I have them and I honestly don't think they deserve the hyperbolic praise they get, in my opinion. At least not for 200 dollars. I was very underwhelmed after I went for a test drive after I installed them.
                              I could tell very, very, little difference, caster and wheel position in wheel housing aside, when I swapped from my solid centered RUBBER bushings. I have some very aggressive caster where I rub very easily on my fender liners/under panel when I turn in, and also rub the inside wall of my opposite tire simultaneously on my IE sway bar.
                              Since it has been a while that I've had them on, I may go back to a solid centered bushing, or an offset e30 M3 bushing. Maybe I will notice a difference then.
