How far forward (caster) are your front wheels?
  • noid
    • 1537
    I just measured and I have about 1.5-1.75" distance from the front valance. Is this normal? Seems a bit to close, from the back of the tire to the fender is 2.5". I am running stock 14" weaves on 195/65/14 falken 912's. I am planning on getting some treehouse racing eyeball control arm brackets, but considering I only have 1.5" with stock non-m bushings and lemforder control arms, I am having doubts.
    Can anyone measure how close their tire is to their valance and also indicate what control arm and control arm bushing your running?
    Front:
    Rear of front tire:
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • 34844
    the offset arms aren't going to move the tire forward very much.
    you have spacers or something?
    • noid
      • 1537
      Everything is stock. Stock weaves, with stock tire size, new lemforder control arms and non-m lemforder control arm bushings and new meyle tie-rods on both sides.
      • noid
        • 1537
        Results from the alignment I had done after everything was installed:
        8.3 and 7.8 degree caster seems high for a stock setup doesn't it?
        • Fusion
          • Nov 2009
          • 3659
          Maybe your valence is slightly bent back?
          The only way to move the wheel forward would in theory be different control arm bushings, a different control arm itself (its angle), subframe somehow moved.
          Caster on our cars can be changed by moving the whole strut/shock assembly forward or back by means of a camber plate, but this doesn't mean the wheel should move.
