Tie Rod install question
  • RawToast
    • Nov 2011
    • 324
    So I'm in the process of swapping my tie rods. I ordered Lemforder ones but here's my question; is it necessary to pack the inner tie rod ball joint with grease (if so what grease) and where can I get clamps for the dust boot cover?
    Thanks
  • reelizmpro
    • 9537
    IIRC, they are already lubed. You can get those clamps from any parts supplier. I just reuse them.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • frankie591
      • Feb 2012
      • 545
      the tie rods should come pre-packed. Just use zip ties for the tie rod boots.
      • RawToast
        • Nov 2011
        • 324
        Also should I buy a new locking plate?
        • AndrewBird
          The Mad Scientist
          • 11898
          You don't have to unless you mange to break your old ones un-bending them. If you are making an order, it would be worth it to get news ones just in case.
          • frankie591
            • Feb 2012
            • 545
            Blue locktite works just fine as well, but it's up to you.
            • nickmcc92
              • Dec 2012
              • 442
              There is no possible way to reuse the locking plates. You'll need new locking plates, tie rod assemblies, and boots.
              Easy job just a pain unbending the locking plates. (Chisel, hammer)
              Good luck!
