Custom 4 piston Ap brake kit
This topic is closed.
    Just for everyone to know.
    Such a kit, with AP Racing calipers, already exists and a few copies have been sold by Terry Gosse at KVR and used on e30s from Toronto's Trillium chapter members. It is a great kit, but expect to pay a premium price for it. CP5200 calipers are very $$$. Rotors are still only 290mm x 28mm and cost also $$$.
    It all depends on how much $$$ you guys want to spend. There are $150, $600 and $6000 calipers. Which one do you really need?
    massivebrakes.com
      Is ths the kit Lee?
        Not that kit. This is a one-off set for an e30 M3 using CP5200 calipers and done by IronHead on s14.net
        He ended up spending a lot of time and $$$ engineering his kit. BTW the picture depicts the first version of his kit. The second one had different hats with floating rotors. Ironhead did experience some cracked AP rotors (at the mounting points) but came to a quick resolution with AP for replacements.
        massivebrakes.com
          Originally posted by Massive Lee View Post
          Not that kit. This is a one-off set for an e30 M3 and done by IronHead on s14.net
          his second design is what im copying. idk about the rear tho yet.
          I wanna go Fast
            Also i am going to be using lug mount calipers in the rear.
            I wanna go Fast
              I'm still trying to figure out why some people are so opposed to upgrading brakes on these cars. Granted the brakes are fine for most people, but anytime you start pushing the cars over 80-90 mph the stock 10" brakes are going to start to fade after a few serious slowdowns. Yes upgrading the pads helps, but the problem is the size of the rotor; they just don't have enough heat sink capacity to shed the elevated temperatures consistently. Just by going to a larger rotor and keeping the stock calipers would result in a good advantage over the stock rotors.
              I guess it all comes down to priorities; I'd rather have the big brakes and know they will never fade, than to worry if I have enough brake for that next blind corner coming out of the mountains...
                I dont think you get any better quality than what you will find in lee's kit.
                Wilwoods are fine and the superlites are a good bit of kit with the cars, but if it isnt you and you want to pay through the nose, you can use a rotor/caliper of you own chosing.
                Just a little project im working on
                - http://www.lse30.com -
                  When you rush in at 100 MPH toward a corner, it's not the time to wonder if you have enough brakes, or not. Not to mention that between sessions, most drivers have better things to do than bleed their brakes...
                  Anyway, when I designed the first kits, several years ago, I never thought they would sell more than a couple of sets per year. Here's a picture of the two first kits I made. Hats were very simple and turned by hand. No CNC then. One kit was for 11.75" x 0.81" rotors, while the other was for 12.2" x 1.25" discs. Those were the first kits and perhaps 5 generations of improvements have been done since then. The original kits are still being tracked by their owner.
                  massivebrakes.com
                    Bingo! We have a winner.
                    Even with brake ducts, heat is an issue if you are generating any speed in the straights.
                      BTW If somebody is building a kit around 14" rotors , then there is no reason to go to StopTech or AP Racing calipers. Wilwood now makes the W6A (6 pots) and W4A (4 pots). They are huuuuge, have big pads and are not too costly.
                      One the left - W6A - Uses big pads (40% more surface than Superlite pads but 17mm thickness).
                      Center - Race SL6R - Uses thick 21mm pads
                      Right - SL6R-14" - Uses thinner 17mm pads
                      massivebrakes.com
                        I have my reservations about willwood calipers but lee is a stand up guy to deal with and is awesome for going out there to make really nice custom parts for us e30 people, who we all know aren't the biggest/easiest market out there.
                        ApexRaceParts.com - Facebook - Twitter
                          Meric...I am very interested. How much would the kit cost from you??? Would someone just have to order the calipers from AP and they would match your kit?
                          '91 318is Alpine II- || HR Sport || Bilstein Sport || Poly RTAB || Treehouse FCAB || Poly Motor Mount || Poly Tranny Mount || Poly Diff mount || IE Sway Bar || BA HP Coils/Wires || 19# Injectors || SSR Comps w/10mm spacers || Hawk Pads || Fog Delete || Magnaflow Exhaust || Z4 3.0 SSK ||
                            Just get one of Lee's kits. The development is already done and it will probably be a damn sight cheaper...
                            '89 325is S50 Track Montser
                            '04 X5 Daily/Tow Vehicle
                            http://www.avarestoration.com
                            http://www.myspace.com/brendanfiddle
                            Click here if you want to be my zombie slave...
                            http://www.youtube.com/user/Fidhle007
                              Does Lee have a website or should I just PM him????
                                Hi longms..
                                Here's the website. Prices are of a year ago when the US $ was strong. Expect to pay 10% more. Currently updating the website.
                                Performance brakes and accessories exclusively for BMWs
                                And here's the development album (about 400 pictures that depict the various steps in the development). I believe I produce the only full-race kit using 32mm thick rotors in the world for non-M e30s, that fits a 15" wheel. No need to go to 5 lug swap to get better brakes.
                                Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                                massivebrakes.com
