So recently I've got this horrid noise when I turn the steering wheel to the right and it's very annoying. I've read up on this and determined it to be a bad rear wheel bearing however it doesn't seem like a simple drive way job and requires $ tools. How much should I expect to pay for one and is it recommended to do both if only one is faulty?
How much should I expect to replace wheel bearing
If memory serves, book calls for 4.4 hours for both sides, so that plus the bearings and whatever else the shop decides needs replacing(brakes, e-brakes, axle/boots, etc.) while they are in there. -
I took mine to a BMW shop (independent) to get it replaced. It cost $180 or so all said and done.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
Yea fronts aren't bad
Cheap ^Comment
If its noisy when turning that would typically point to the front bearings. Under vehicle noises can be tricky to source just by ear so its a good idea to jack up the font end and check them (3&9; 6&12).
If you do take it to a shop, never tell them whats wrong, but rather say "I think but please confirm". That way if its not what you "think" it's on them. A good shop will do their own diagnosis but...Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
