Soft brakes, air leak?
  • MR.LUGO
    • 905
    Hey guys, bled my brakes yesterday due to the pedal being very soft and spongy and pretty much hitting the floor, now after the pedal is stiff at first and then softens up and is hard at the bottom again which is even sketchier than before because it brakes unevenly. What are some signs that it might be the master cylinder or brake booster? Thanks!
    Got all da Alpine bitches mad cuz my main bitch Calypso.
  • Earendil
    • 1662
    Subed.
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    • kickinindian
      • 2327
      in for more info!
      • FLG
        • Sep 2011
        • 3165
        Losing any fluid? If you pump the brakes do they return?
        Looks like a master cylinder issue.
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • Andy.B
          • Sep 2011
          • 1650
          Bad booster would cause a vacuum leak and constantly stuff pedal.
          Sounds exactly like a bad matter. Push rod seal is holding, but the internal seals are leaking past each other.
          Sounds exactly like mine before I replaced it.
          • MR.LUGO
            • 905
            I don't think so, i was thinking it could be the lines. Yea the pedal does return.
            Sooo what exactly did you replace? Haha
            • DEW
              • 26
              I think he meant bad master. As in bad master cylinder.
              • MR.LUGO
                • 905
                Ah, i see. Makes sense. Well i guess it wouldn't hurt to replace it. Hopefully that'll do it. Thanks!
                • Earendil
                  • 1662
                  Couldn't hurt?
                  I suppose I don't know what people's budgets are for these things, but the two places I found online that would sell a brake master cylinder were pushing $200+
                  If I can rebuild calipers, differentials, and heads, I should be able to buy a $20 gasket set to rebuild a Brake MC instead of dropping a track days worth of money on a new one. Or am I missing something? I hope I'm missing something.
                  • FLG
                    • Sep 2011
                    • 3165
                    Just replaced mine with a 740il Mc (25mm) and love it. Brakes are super firm.
                    Paid 135ish for a new ate Mc
                    • MR.LUGO
                      • 905
                      Originally posted by Earendil
                      Couldn't hurt?
                      Ha i kinda take back my "couldn't hurt" comment, i actually hadn't looked them up, i thought they were closer to 50-80 bucks :/ lol.
                      • MR.LUGO
                        • 905
                        Nice i was reading up on that as an upgrade, i thought it was just the 750iL, or is it either as long as it's 25mm?
                        • FLG
                          • Sep 2011
                          • 3165
                          Nope sorry think your correct.
                          Believe a 5 series one works too.
                          I'll get you a pn tonight I have the box at home
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5246
                            Running into what seems to be the same issue on my ix, planning to replace the calipers with some spares that actually bleed before I actually swap out the master.
                            Originally posted by priapism
                            Originally posted by shameson
                            • kickinindian
                              • 2327
                              Master did the trick!
                              Sent from my DROID3 using Tapatalk 2
