I have acquired a straight left rear trailing arm to replace the bent one on the car. Is is possible/advisable to change out the trailing arm with the subframe in place, or does the whole enchilada need to come out? Sadly, I just paid a shop to install OEM subframe and TA bushings, so there's no "while you're at it" incentive to drop the subframe. BUT if the subframe has to come out again, I'll have weld-in adjusters put in. Dang money pit...
swap TA without removing subframe?
I just did mine without taking it out. It wasnt bad at all actually. I had trouble getting my subframe out, so i left it in. Jack up your car pretty high before you start.Haven't you ever seen Russian Nesting Dolls? They work like that.
1987 325e / 2008 135iComment
There is a write up here that makes it seem fairly easy to do without removing the subframe.
sigpicComment
