stripped rotor bolt
  • TimbyMaTombo
    • Jul 2012
    • 413
    stripped rotor bolt
    In trying to get the rotor off my car, I found that it is somewhat rusted into place, over torqued, and stripped. I tried undoing it but stripped it further so I tried slotting it with a dremel and using a flathead screwdriver but I don't have any wide enough. The rotor needs to be replaced so I'm not worried about messing it up.
    What should I do? Go see if Wal-mart has that drill bit thing for stripped screws?
    Thanks,
    Peter
  • travish325
    • Jun 2012
    • 1151
    either that or drill it out
    • FLG
      • Sep 2011
      • 3165
      Just drill it out
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • IronFreak
        • Dec 2012
        • 3702
        ......Walmart?
        Try a hardware or auto parts store before spending any money on tools from walmart.
        Instagram @rebellionforge
          Use a drill slightly larger than the body size of the screw to drill the head off. That lets you get the rotor off and leaves enough of the remains to grab with vice grips. Soaking the screw with PBlaster fo a day or so will help in removal. Use anti-sieze on the new screw.
          • Earendil
            • 1662
            Also of note, that little screw is a convenience. It does not keep the rotors in place during operation, the wheel lugs do that.
            1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
            2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
            I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
            • travish325
              • Jun 2012
              • 1151
              Originally posted by FLG
              Just drill it out
              Lol
              • FLG
                • Sep 2011
                • 3165
                Yep but if your not running studs you'll appreciate that convenience lol
                • 318isnages
                  • Nov 2012
                  • 5
                  using a centre punch usually works to undo it that little bit, hitting it on a angle on the outer section
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    When rusted in, I often will hammer a larger Torx into it and use a small battery impact to pull them - if that fails, use Jim's advice.
                    I keep them in stock, just for when customers like you come in. I hate trying to line up the rotor/wheel when using the OEM lug bolts. They are less than $2 each - you guys can't really be that cheap.
                    john@m20guru.com
                    Links:
                    • TimbyMaTombo
                      • Jul 2012
                      • 413
                      Thanks everyone for the advice. I won't be able to do anything until Friday due to school, but I liberally applied PB Blaster and will do so again tomorrow night and try drilling it out Friday.
                      Only reason I said Wal-mart is because I live across the street from one. I don't do my tool shopping there, don't worry... I usually get stuff from Ace but went to Harbor Freight for the first time today to get a ball joint separator. Worked amazingly but startled me the first time with the loud pop when it came undone.
                      Peter
                      • Earendil
                        • 1662
                        That's got to be one of the best shade tree mechanic moments, especially when working solo:
                        "#%^*!!! Was it supposed to do that?!?!"
                        • Roysneon
                          • 4505
                          I don't think he's advocating not using them, just putting it out there. The reason they are there is so that the holes in the rotor remain lined up with the holes in the hub.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • Earendil
                            • 1662
                            Can't be that cheap? Are you new here? :D
                            But in all seriousness, my point was that the OP shouldn't worry about damaging it. He can bugger the thing up, and be okay driving to pick up the part, or waiting 3-5 days to have a new one shipped.
                            That said, I do not have them on the back of my car for two reasons:
                            1) The E-Brake holds the rotors on just fine.
                            2) I'm a forgetful sob.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Yup, just signed up ;)
                              Still, it's a peeve of mine, therefore, there's a bag of part number 34111123072 in my drawer ROFL.
                              Yes, I own an e30, therefore, my track wheels are XXR :D
                              john@m20guru.com
                              Links:
