Removing Poly Trailing Arm Bushings
  • Earl
    • Feb 2013
    • 31
    I just installed a set of poly bushings in my 318ti trailing arms, but i need to remove them. I found out that the sleeve ID wasn't machined to 12mm. It is 10.9mm, which is the stock the manufacturer uses. I also installed them wrong and trapped air, causing them to keep from fully seating. I have tried pulling them out, pressing the sleeve out, and drilling a hole to relieve the air, but nothing has worked. What do you guys recommend?
    Push or drive out the sleeve. The bushings will then easily come out.
    • Earl
      • Feb 2013
      • 31
      I tried that already. The sleeve is in there too tight.
        It will come out. But you may have to press it out or use a puller.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Put the bushings in first, then push the sleeve through. So much easier than trying to force air out.
          To get them out, youre going to need to remove the sleeve first. A few sockets and a big c clamp should be all you need
          Originally posted by priapism
          Originally posted by shameson
          • cdubvw
            • Feb 2013
            • 18
            Cut one end off
            • Earl
              • Feb 2013
              • 31
              I tried two sockets and a c clamp but the sleeve is in there too tight and the clamp keeps slipping off.
              If I cut off an end, the bushings are shot. lol I would have gotten them out already if I wanted to destroy them.
              I'm borrowing a 12 ton press to do my wheel bearings, so hopefully that gets the sleeves out.
