Heavy grinding from brakes driver side
  • edsel1134
    • Apr 2013
    • 194
    Ok so you guys were right no joke welcome to heaven and hell. So got the car and the brakes were bad.. Still stopped but the pedal was soft and had to compress hard to stop.. Ordered all 4 rotors and pads. Since it was my first time working on the e30 I did driver side frond first.. No errors smooth sailing.. Putting the tire on was a bitch lol.. Anyways test drove no noise everything seemed fine.. Next day replaced the pass side.. Same story.. Then drove it.. And horrid grinding noise from driver side.. Upon inspection everything seems fine.. Pulling the tire tomorrow. I ordered a set of 4 drilled slotted rotors and brake pads. Note: soft pedal is still there and if I double pump pressure builds.. Waiting on brakedfluid I ordered. So any ideas thoughts will help.. I'll take pics tomorrow.
  • george graves
    • 19998
    Flush and bleed the brakes. If there is grinding somewhere - you'll see it.
    Originally posted by Matt-B
    • edsel1134
      • Apr 2013
      • 194
      Yeah but still confused why that side grinds and pops and such when I'm braking
      • george graves
        • 19998
        Yea...it's a real mystery. ;) I'm thinking you should take that wheel off and take a look.
          Inspection of that caliper and wheel bearing should reveal the cause. The braking problems could be air in the system, a bad master cylinder, or a problem with the booster.
          • hooken m
            • 1537
            this and the caliper bushings could be shot? caliper needs rebuild?
            Originally posted by evandael
            a car is a car. call it a dildo, i'd still drive the hell out of it.
            • edsel1134
              • Apr 2013
              • 194
              Once I get home today I'll peak again and take a clip.. Thank you for the help and insight
                Those are possibilities.
                • edsel1134
                  • Apr 2013
                  • 194
                  Yeah but why would it only start doing it after I replaced the opposite side?
                    Because that is just the way things happen sometimes.
                    • edsel1134
                      • Apr 2013
                      • 194
                      >_> dos autos
                      Ehh lol
