ABS failure
  • tcheb
    • Jul 2008
    • 620
    ABS failure
    Hello!
    My ABS is doing some curious things. when I'm coming to a stop, just before I stop I can feel and hear the ABS activate. It does that a few times and then the ABS light comes on and ABS stops working until I restart the car. Then the same behavior repeats itself.
    I recently replaced the dash in the car so I had to unhook the ABS brain... It might have something to do with that...
    Any advice would be greatly appreciated!
  • kickinindian
    • 2327
    clean your wheel sensors?
    • saturnv7890
      • Jan 2011
      • 696
      the wiring under the fender gets pretty crusty too
      My Transaction Feedback
      My "build" thread
      BUY MY CAR!!
        My first suspicion is that you have a failing wheel speed sensor, or one heavily contaminated with ferrous dust. But it is possible that the ABS module has a bad input channel or even a problem in the ABS sensor wiring. Cleaning the sensors may help, but if that doesn't work diagnosing the problem will probably swapping in known good parts
        • E30_Pare
          • 7801
          Rip it all out. ABS is for women & monkeys!
          DREWLIENTE
          1$ PShops PM me
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5604
            • KHTRNAK
              • Jul 2013
              • 52
              I think that's what the previous owner did on my car; I guess that's why the light is on forevermore.
              '87 325is (Toy)
              08 Acura TL-S 6MT (DD)
              • Maddog
                • Dec 2006
                • 117
                I had the same problem several years ago and it was one of the wheel sensors. I tested each sensor to determine if it generated the specified mV.
                Attached is the ABS diagnosis writeup I used to test the sensor. All you need is a voltmeter; I disconnected the sensors and measured the mV on each sensor by spinning the wheels.
                • tcheb
                  • Jul 2008
                  • 620
                  Thanks! I'll try that.
