No more squeaky bushings
  • e30topdown
    • 94
    I thought I'd share my experience when I replaced my subframe bushings, rtabs, and diff carrier bushing with AKG polyurethane bushings. I had originally bought all OE rubber bushings from Lemfoerder and the diff bushing was OE from Corteco, who is an OEM supplier for BMW. But I was talked into the AKG polys by a tech at BMW of Austin who was going to help me put them in. I ended up getting 85A polys for the subframe and diff, and I got 75D rtabs. As it turned out, for various reasons, the dealership ended up putting them in for free. (Yes, there is a story there.) I picked up the car from the dealer about 3 days before we left for the e30 Picnic in June. And the rtabs squeaked like hell. If you were at the picnic, you probably heard us drive in...and knew right away what was causing all the noise.
    So I ended up dropping the rear subframe yesterday and put it back today. What I found was no grease whatsoever in the grease grooves of the rtabs. I kinda already knew that, but I can't for the life of me figure out why the tech who worked on my car didn't put any grease in there. Well, I packed the inside of the rtabs with blue marine grease (after scouring the forum, there seemed to be more people squeak free from the blue (or green) marine grease). I used CRC's StaLube SL3121. It's for boat trailers and 4X4 wheel bearings...mud and wetness. This stuff is supposed to have a high resistance to wash out and also is effective at temps up to 375 F. Cost was $8.97 Prime on Amazon. Worth every penny! I pressed out the metal sleeves and just left the bushings in the trailing arm. I used my little finger to put alot of grease inside the bushings. I then pressed back in the sleeves. It matters if the sleeves are flush or sticking out even a hair. Make sure they are flush with the bushing on each end. (I wasn't very careful on the second trailing arm with this, and it squeaked after I put it back in.) I also lubed up the ends of the bushings and sleeves before reinstalling in the trailing arms. Don't know if this really matters, but it made sense to me.
    After getting the car back together, I took it for a test drive awhile ago. Quiet as a mouse...the suspension was anyway. Rough roads didn't matter. I'm really glad I did this. I wish the dealership had greased the rtabs the first time. I wouldn't have been under the car for two days, otherwise. I really hope the marine grease lasts a long time, too.
    BTW, we put 5676 miles on the car on the road trip to WA. It handles better than it ever has, probably even when it was new. I have MZ3 solid rubber fcabs on heavy duty Meyle control arms. I have stock cabrio springs with Bilstein HDs all around, so it's not slammed. But it does carve up the mountain twisties. I've never had a car that just loves to be thrown into curves. My M Roadster handles like its on rails, but I do have to be ready for oversteer with it. The two cars handle very differently, of course. But this e30 vert is a blast to drive. I never could upset it, even when pushing it hard through several mountain ranges.
    I hope this info helps others. Sorry for the long post. But I wanted you guys to have details.
    92 325iC Diamantschwarz factory M-Technic appearance
    99 M Roadster Dakar Yellow II
    97 318ti Active Bostongrun DD
    01 Z3 3.0i Coupe Black Sapphire
    93 325iC Schwarz II. Sold, but not forgotten.
    I hope you have better luck, but the times that I've used poly bushings on a street car I've had to re-lube them every year. Synthetic brake grease seemed to last longer than marine grease, but that might have been just differences in the weather the car saw. As a result I no longer use poly bushings on a street car. Fresh OE parts are almost as good.
    • e30topdown
      • 94
      Good to know. Of course i had read some of your comments, Jim, while researching the issue. I came very close to changing the AKGs out with the Lemfoerder rubber rtabs while I had the subframe dropped. In fact, I almost changed it all over to OE stuff, just based on what you had posted. I reasoned I could sell the polys. But I really wanted to see if the marine grease got rid of the squeaks. I could tell by just moving the trailing arms up and down after greasing them that they were quiet. Just five minutes earlier they had groaned with every movement up and down. We'll see how long the silence lasts. I'm happy for now. If (when?) they start getting noisy, I will go back to rubber. Now that I've dropped the subframe once, I feel certain that a second go-round wont take near as long.
      • SkiFree
        • Jun 2011
        • 2766
        Going on three years squeak free suspension urethane here. As for lube, there's more than one way to handle, my magic sauce was silicone-based dielectric grease. Same thing prothane uses and plenty of other urethane producers.
        But isn't the silence nice?!
        ADAMS Autosport
        • e304me
          • Feb 2006
          • 1374
          I am done with poly, for the trailing arm and control arm bushings at least. Going to change them out for OEM.
          • e30topdown
            • 94
            Yes it is. After three weeks and 6500 miles of squeaky squeaky, the car is the once again the refined vert she should be. :D
            • StereoInstaller1
              GAS
              • 22679
              Marine grease lasted me 3+ year and well over 30K.
              It is not as rainy here as people say, but it is constant drizzle for months.
              Washout has not been an issue for me...but I am still doing zerk fitting on my next Urethane upgrade.
              Closing SOON!
              Thanks for 10 years of fun!
              • e30topdown
                • 94
                How's that? Would you just put the zerk fitting in the trailing arm bushing carrier. On the side or on an end where the bolt head is? The grease needs to work up into the middle between the bushing and the sleeve. Just trying to imagine it.
