IE Trailing Arm Bushing question
  • ye12
    • 15
    I'm in the process of installing IE Camber & Toe-in adjustment plates and also trailing arm & cross member urethane bushings. Could someone tell me if these IE trailing arm bushings squeek after a while? I've have ST urethane sway bar bushings and urethane camber kit bushings on other vehicles start squeeking ...... thanks!
    • 34844
    never heard a single squeak in 3+ years.
    • JRKOUPE
      • Dec 2004
      • 3159
      bushings
      I installed my IE subframe and rtab AND a used 4 10 diff all at same time. I do hear some groaning and squeaking on low speed tight parking lot turns......I guess it could be my used diff but I think its a combination of both.
