Why does my antilock system turn off and on? Help abs not working!!
  • millsamus
    • Jul 2012
    • 481
    Help!
    After starting the car I have no lights on my cluster. Shift into first gear and after moving less than 10 feet my antilock light turns on and my abs does not work. Keep in mind I have confirmed that my antilock system DOES work.
    What should I look for?
    Bad fuse?
    Loose connection?
    Do I need new abs sensors?
    Thanks for your time! I need to get ready for snow!!
    My E30 332iS Build Photo Album :) Click below!!!!!!!!!!
    http://s637.photobucket.com/user/mil...2%20SWAP/story
    If you have bought or sold parts from me please visit my Transaction Feedback Thread!!
    http://www.r3vlimited.com/board/show...10#post3791810
  • Stanley Rockafella
    • Aug 2011
    • 4062
    why do you need ABS anyway?
    • millsamus
      • Jul 2012
      • 481
      We'll for one thing I like everything to be working on my cars. Plus the abs light drives me crazy. It helps in the winter. That's why I'm askng while I can still fix what ever it needs.
      • Gregs///M
        • Mar 2012
        • 2459
        I would start by replacing your ABS system fuses. Dont check them, just replace those old 20+ year old suckers.
        Also replace your ABS relay, its really old and could be causing intermittent issues.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • jalopi
          • 2370
          If the ABS light is out when you start the car up and only comes on once you get moving you've got a sensor issue. Figure out how to pull ABS codes on these things... I don't know cuz I don't care
          • millsamus
            • Jul 2012
            • 481
            Sounds like I will check my Bentley to find the relays. I have a hunch it's the relays right next to the air box under the hood. To describe it better it's the small plastic black box that has 3 relays under that cover which pulls right off, no tools necessary.
            • Vtec?lol
              • Dec 2009
              • 3278
              you need new sensors and relays
              • woodisgood
                • 1087
                check the sensors on your brakes. Cant remember exactly how it works but at 10mph they starting sending some sort of signal. The wires are very thin and easily damaged. Also new sensors are like 89 bucks a piece and good luck finding used ones.....
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Check your sensors. They are magnetic and stuff can stick to them, causing funky readings.
                    One or more of the wheel speed signals aren't present at the ABS module, or the module is faulty.
                    Troubleshooting the ABS system isn't very difficult. It is a standalone system
                    that only gets input data from the brake light switch, wheel sensors, and
                    system power. The parts of the system are the ABS module located next to the
                    steering column, the ABS relay mounted above the ABS module, the ABS unit in
                    the left front of the engine bay, and a speed sensor at each wheel.
                    If the ABS light comes on with ignition, but doesn't go out when the engine
                    starts, a wiring problem, bad module, or bad ABS relay are the likely
                    candidates. A failed or weak alternator will also cause this because the
                    system voltage won't rise enough. There is a fusible link inside the ABS relay
                    that can be blown. The relay can be repaired, or better yet, replaced. The
                    relays in the ABS unit can be replaced.
                    If the ABS light comes on when you turn on the ignition, goes out when the
                    engine starts, and then comes back on before the car is moving the cause could
                    be a bad module, a bad ABS unit, or a wiring fault.
                    If the light goes out after engine start and only comes on when the car is
                    moving, there's a problem with one (or more) of the sensors. The simple test
                    to find out which sensor(s) is the cause is to disconnect all but one of the
                    sensors and drive the car. If the light comes on, that sensor is sending a
                    speed signal to the ABS and is good. Repeat with each other sensor to find the
                    one(s) that don't cause the light to come on. Since the ABS module has no
                    speed input besides the wheel sensors, if only a bad sensor is connected the
                    module can't tell the car is moving and thus doesn't fault on missing speed
                    signals from the other wheels. Once a bad speed sensor is found, if a new
                    sensor still doesn't work, there could be a wiring fault in that circuit or a
                    bad input channel in the ABS unit.
                    • millsamus
                      • Jul 2012
                      • 481
                      Very good information here! Sound like i know my plan!
