E-brake doesn't hold
  • srvE30
    Voodoo Child
    • Jun 2013
    • 408
    Brake handle has tension and the car "pulls" but the brake doesn't hold the car on a hill. It goes rolling on down. Any ideas?
    1989 325i Cabrio
    tyzg
    Midwest E30 Owners Gruppe Facebook
  • ELVA164
    • 4861
    How much adjustment have you put into the cables? Sounds like the shoes might just be worn out and can't reach the drum enough. Also, I believe spec adjustment is 5-7 clicks until the handle stops moving.
    • srvE30
      Voodoo Child
      • Jun 2013
      • 408
      It's all adjusted right. I'm sure it's something under the car. That might be the issue. The car still has some old stuff from when it was garaged for 10+ years
      1989 325i Cabrio
      tyzg
      • AndrewBird
        The Mad Scientist
        • 11898
        Pull the rear disks and check it out.
        Also, how do you know they are adjusted correctly? I mean, the correct adjustment is where at 5-7 clicks, it holds the car. Are the nuts on the cables adjusted all the way down?
        • srvE30
          Voodoo Child
          • Jun 2013
          • 408
          Yes. It was sitting a bit high originally.
          1989 325i Cabrio
          tyzg
          • ELVA164
            • 4861
            Sounds like the shoes to me, or possibly stretched cables.
              My first suspicion is that the parking brake has been incorrectly adjusted by fiddling with the cables. The correct way to adjust is to:
              1) Lower the hand brake and loosen the cable adjusters.
              2) Working through a lug bolt hole turn the star adjuster until the wheel
              locks using a flat-bladded screwdriver. I just turn the adjuster until it
              doesn't want to turn any more. Then back off the adjuster 12 clicks. Repeat
              for the other wheel. Note that the star adjuster is at the 6 o'clock position
              on later cars, but at the 10-11 o'clock position on an E30.
              3) Raise and lower the hand brake several times to settle the cables. Then
              raise the lever two clicks and tighten the adjusters until the wheel can just
              be turned with moderate force.
              • srvE30
                Voodoo Child
                • Jun 2013
                • 408
                Will go over again. Thanks
                1989 325i Cabrio
                tyzg
                • Cletonius
                  • 2809
                  Thanks for the steps Jim. Been meaning to adjust my brake for a while now
                  - Josh
                  1990 325is
                  Need a shift boot?
                  Looking to buy shift boot frames, PM if you have one to sell
                  Here's what happens when you let the internet pick your license plate
                  • Roysneon
                    • 4505
                    I'm having the same issues. I have new hardware, new shoes, new disks and replaced one broken cable. the car slowly rolls ahead even with the shoes adjusted outward just enough that they let the wheel roll and the cables are adjusted as tight as I can get them. The cables bring the shoes tight against the drums but the car will still creep if on a hill.
                    I'm going to try to go through the procedure Jim suggests and hope it works for me.
                    Originally posted by mbonanni
                    I am a pursit now.
                      If you don't follow the procedure above and just adjust the cables, the operating lever that expands the shoes won't have the leverage that it should and the shoes won't be clamped tight to the drum.
