I'm looking to put in a subframe from a 91 IX into my 91 325 and the car will be tracked and autocrossed. I saw condor has a kit and I could get the same thing from Ireland engineering? Anything better?
Best rear subframe urethane kit.
1991 325i Calypso Coupe
Like Grandfather, Like Father, Like Son
BMW
Tags: None -
Condor products are made out of UHMW which is a hard plastic. Akg, IE, and Revshift; just to name a few, all offer polyurethane base bushings. Now which one is best you ask? Well, you'll find different answers because everyone has their own personal preferences based on experiences or w.e. But in general, if your seriously tracking this vehicle, Go solid.
Btw, I have a complete bushing kit from Akg (75d) for the rear end if interested
HamLast edited by Thing30; 12-16-2013, 02:52 PM. -
if it's gonna be tracked, condor all the way!
Sent from my SCH-I545 using Tapatalk 2Comment
I run Condor. Just got my trans mounts! I will be all condor'd up once I get these in.sigpic
Instagram: @DrLeadFoot
Build Thread for the Turbo S52:
http://www.wibimmers.com/board/index...turbo-install/
Running log of the daily E46 M3:
http://www.wibimmers.com/board/index...46-m3-journal/
Flickr
https://www.flickr.com/photos/70254549@N06/
I run condor motor+trans mounts and revshift bushings everywhere else. I just bought whichever had the better sale on black friday. Everything is holding up with no problems so far.Comment
I probably should have mentioned its a DD as well.1991 325i Calypso Coupe
BMW
But condor is sounding like the right choice. I would like to have most to all of my suspension bushings the same hardness and by the same company.1991 325i Calypso Coupe
BMW
I run condors compete line, it's still dd'able (though i don't do, if the car was less of a drift rat I'd have no issues tho) the trans mounts do cause the most noise and vibration.
Do whatever floats your boat, but do some research. The condors are the latest to get some fanboyism. Before that it was revshift.. before that it was akg. .... in another couple years it'll be the next guy. For me there is no way in hell I'd run umhw on a street car. On a race car I'd only use them for mounts if there was no other option (wouldn't even consider it for a bushing given its deformation characteristics.)
I'm all for supporting the community... but ireland, akg, and r3vshift have already been doing that for longer already.Comment
if i did the job again i would run poly in the subframe and diff mounts and condors stuff in the trailing arms88 325is Five SpeedLachssilberComment
I have Irelands in a DIRT track car. on the rears. and have had NO PROBLEMS. put revshift for engine mounts and they broke in the second night (drilled them out and made them solid)
but I recommend IE. you want it more solid then stock rubber if your tracking it!
sigpic1984 318i Total conversion to a DIRT race car.
Check out our build on facebook @ www.facebook.com/brewstermotorsportsComment
