Best rear subframe urethane kit.
  • IronFreak
    • Dec 2012
    • 3702
    I have IE subframe bushings. they're Poly but still REALLY stiff. I have seen the Condor as well, very nice stuff. you have had the full layout of whats what in the above posts. decided what the car is going to be used for and select accordingly.
    Instagram @rebellionforge
    • Holland
      • Nov 2008
      • 7212
      Originally posted by jlevie
      For a track or race car, I use AKG aluminum subframe and differential mounts.
      I'm using Turner aluminum mounts, and I love them.
      Originally posted by DEV0 E30
      • Zreberlcoe
        • 1555
        So I got hung up on the removal of the bushings
        *face palm*
        I went with the way this guy did and I couldn't get it to push out. http://www.rtsauto.com/e30-rear-subf...l-and-install/
        I tried to burn them but they didn't light up like other people's success.
        Help me out here.
        1991 325i Calypso Coupe
        Like Grandfather, Like Father, Like Son
        BMW
        • silence
          • Jun 2007
          • 1824
          *face palm*
          Help me out here.
          Buy a propane torch at Homedepot in the plumbing section, once you heat the metal around the bushing enough, they slide right out.
          •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
          •• Rear Subframe Bushings • RTABs • Facebook ••
          • matthugie
            • Mar 2004
            • 1810
            Burning didn't work for me either. Ended up pressing them out.
            88 325is - S52 powered
            Originally posted by King Arthur
            We'll not risk another frontal assault, that rabbit's dynamite!
            • berlow94
              • Jan 2013
              • 1063
              Sit on em with a handheld propane or map gas torch. Once the rubber gets soft enough, separate the inner metal stuff from the outer sleeve. Then take a saw and cut the outer sleeve. Don't go too deep or you'll cut into the subframe, but as soon as you get all the way through, it is a pressfit so the tension should instantly be released and they literally "pop" out.
              Sent from my Nexus 5 using Tapatalk
              The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
              • iansane
                • 1343
                I just did the MAP gas technique on my subframe. Worked well. I burned each side for a couple minutes and then with a ball peen hammer just whacked out the inner metal sleeve. Once that was out I hit each side again with the torch and then burned themselves out in a couple minutes. Then just a hacksaw to cut a slit in the outer liner and I could pound them out with a hammer/punch.
                84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                • Herr Faust Schinken
                  • Feb 2012
                  • 3580
                  If you have access to a 10 ton press use that, me and my friend tried to burn the bushes out and it dosen't really work. We ended up pressing all the bushings out in like 15 minutes
                  88 325is Five Speed
                  Lachssilber
                  • Zreberlcoe
                    • 1555
                    Alright guys I went into my metals shop at school and used a arbor press like this one
                    and pushed them through. Good to go!
                    BMW
                    • Zreberlcoe
                      • 1555
                      I was also about to order the subframe mounts from ireland (street use/green ones) and theyre out of them :(
                      BMW
