Non-offset solid control arm bushings?
  • noid
    • 1537
    Seems as though all parties who sell the non-insert type of solid control arm bushings (Treehouse, BWsport, ebay copies) all make M3 offset bushings; anyone know of a place that sells non-offset in this style?
    Should be easy, make the mounting part longer, and drill the holes slightly farther down.
    Someone who is good with solidworks should get on it already and make a boat load of money :popcorn:
    For those who are unaware of the style I am referring to:
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • ak-
    • 12422
    Solid/Poly regular e36 bushings? That's what I'll be getting since my tire hits the valance with offset bushings.
    1991 325iS turbo
    • kamotors
      • Nov 2007
      • 7102
      AKG adjustable
      7speedshop.com
      • noid
        • 1537
        Originally posted by kamotors
        AKG adjustable
        I wouldn't call those street-able, there is no sleeve and would require proper adjustment and checking.
        • kamotors
          • Nov 2007
          • 7102
          work fine for me:)
          7speedshop.com
          • Keewee30
            • Dec 2013
            • 4
            I use, and highly rate condor speed shop delrin fcab's
            I am using centred (non-offset) in my E30 drift car to develop less Ackermann at full lock than offsets will, currently 8.5' caster with centred bushes doesn't need more.
            • JGood
              • Jan 2004
              • 7959
              I've also been looking for a treehouse-like design in non-offset spec. I need clearance for V8 headers and don't like the way my wheel is offset forward in my wheel well with my e30 M3 CAB's. This thread reminded me, so I started searching again.
              Check out Bimmerworld's page for Treehouse CAB's.
              They have the Treehouse offset bushings, but also mention a centered bushing. The e30, e36, and Z3 all use the same Treehouse offset bushing part number. The centered bushing is only listed for the e36 and Z3, but it almost has to be applicable to e30's as well. I'm going to send them an email just to confirm, but this should be the part we are looking for.
              EDIT: Here is the Treehouse page for this bushing:
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • JGood
                • Jan 2004
                • 7959
                Bimmerworld just responded... They will fit the e30.
