excessive vibration under braking
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Jeff,
    Everything went together really good, It's nice to have those new tie rods. I also ended up rebuilding the shift linkage and changing the front sway bar bushings with new OEMs. I would have done Urethane but i needed them that day and no where in town has them. hmmm...so rotors. I guess i'm kind of perplexed as to how relatively new Ate rotors that have been recently turned could be out of round already. But i guess i can replace them, they're not that expensive.
    • CorvallisBMW
      • 13039
      btw, what's the best place to get new rotors from? (slotted or cross-drilled would be nice, like the Powerdiscs)
      • fporro
        • 1860
        check swaybar mounts at crossmember, if they're loose your control arm will vibrate during braking.
        pls, don't ask how i know.
        • CorvallisBMW
          • 13039
          I just replaced way bar mounts...they're good.
          • CorvallisBMW
            • 13039
            bump, best place to buy new performance rotors?
