Subframe differences?
  • Haystack
    • Mar 2014
    • 213
    I'm trying to find out if the front subframe of a 325ic will fit my 325. Can't seem to find any solid answers. Or if they are different, does it matter? Thanks in advance.
  • Roysneon
    • 4505
    Yes, they are the same.
    Originally posted by mbonanni
    I am a pursit now.
      • 37832
      All E30 subframes (other than 325iX) interchange.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Roysneon
        • 4505
        However, the m10 and m40 cars (at least with manual transmission) have an additional bracket for a small strut meant to limit engine movement or to just further dampen vibrations.
        I am a pursit now.
        • hurley9
          • Apr 2007
          • 12
          will the rear cross member of an ix fit all other e30s? or no?
          • Roysneon
            • 4505
            The bushings are different but I'm quite sure the subframe itself is the same. My roommate has a non awd subframe in the rear of his ix.
            I am a pursit now.
            • Zreberlcoe
              • 1555
              You can do a 325ix subframe! I did it today. It just has a different offset.
              1991 325i Calypso Coupe
              Like Grandfather, Like Father, Like Son
              BMW
              • Northern
                I like cupcakes & sh!tboxes
                • 5246
                ^This
                Front ix subframe will not work, rear is identical once you swap to the correct bushings
                Originally posted by priapism
                Originally posted by shameson
                • Roysneon
                  • 4505
                  Only the rear hubs make for a difference in wheel offset on the ix.
                  I am a pursit now.
