Rear bearings/rear bushings
  • mathillois
    • Sep 2012
    • 71
    Hey r3vers,
    So in the near future I'm looking to replace my rear bearings as well as rear subframe And trailing arm bushings. I'm wondering what the easier and most efficient way to replace both my bearings and bushings. Should I replace the bearings first? Or just drop the whole rear end and do it all off the car? I was thinking do the bearings first but what do I know I'm a noob.!plent thanks for any advice.
    Marc
  • TSI
    • Mar 2012
    • 691
    I was thinking of dropping my subframe and doing the bearings while it's off, but my bushings were so stuck, I'm putting it off. Don't forget to do your trailing arm bushings too.
    As for the bearings, I did mine with the subframe still on. It's not a hard job to do if you have the right tools, once I got them it took perhaps 30 mins per side.
      With the right tool, the bearings are probably easier to replace with the subframe mounted. The bushings, not so much.
      • matthugie
        • Mar 2004
        • 1810
        I'm with jlevie on bearings. I pulled my subframe to do some other stuff (camber/toe adjusters) so I took my trailing arms to a shop to have the bearings done and the guy complained about how hard it was to do with the arms loose.
        88 325is - S52 powered
        Originally posted by King Arthur
        We'll not risk another frontal assault, that rabbit's dynamite!
        • jeffnhiscars
          • Jun 2011
          • 6011
          Im with Jim and Matt on the bearings. I installed minbe after I replaced the subframe/TA so as not to damage them while it was all apart. Bearings, hub, half shaft..done
          Alice the Time Capsule
          • jrobie79
            • Mar 2006
            • 2526
            i did everything with the subframe out...wasn't easy, but I wouldn't say it was overly difficult either. I didnt have the "correct" bearing tools but i fabricated something similar and had em both changed within 1.5 hours
            1991 318i ---- 308K - retired
            • the imitator
              • May 2013
              • 1006
              I used 3 toothed puller rented from auto zone to get the subframe bushings off.
              The key is to find a washer that is the same diameter as the inner metal ring the bushing sits in, if it's even slightly too small the pressure will be put on the bushing and it won't press evenly and eventually break away.
              The RTABs are quite simple too, Lowes carries 12 inch pieces of all thread, get a big deep well socket that fits over the bushing, slide the all thread through the socket and rtab, use a washer of similar inner diameter on the side with no socket and thread a nut on both sides and go for it. Cost me 3 dollars.
              • mathillois
                • Sep 2012
                • 71
                Thanks for All the replies! This really helped. Thank you all for your advice and input.
