New hawk pads and the wear sensor
  • ebox86
    • Sep 2012
    • 528
    Has anyone had any problems with the brake wear sensor not fitting into the eyelet with new Hawk HPS pads? I am running them all around and the little clip that is supposed to hold t he senor in is too small and just falls out.
    What should i do, just glue it?
    '99 e46 323i - wrecked
    '87 e30 325iS - sold
    '91 e30 325i - sold
    '89 e30 M3 - fun car
    '09 e91 328i - sold
    '97 impreza - rally car - flipped
    '08 impreza - new rally car
    '01 996 tt - more fun car
    '82 Ford f350 - work truck
  • digger
    • Nov 2005
    • 6199
    get proper pads. HPS suck......
    you dont need a wear sensor i havent used one for years and years
    • AndrewBird
      The Mad Scientist
      • 11898
      If you actually want a wear sensor and would like it to work, just silicone it in place. Otherwise just zip tie the sensor up out of the way to keep the light off.
      • FLG
        • Sep 2011
        • 3165
        Just to add.... Hps pads suck.
        Leave it zip tied out of the way worst case, front one should be enough as the fronts will wear faster anyways.
        I didn't have an issue though when I ran Hps pads for the breif time I did. They truly are bad though.
        Sent from my SCH-I545 using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • ebox86
          • Sep 2012
          • 528
          wow thats interesting, two in a row bad reviews for hps, i had previously heard generally favorable things about the pads but im now reconsidering what to go with in the future.
          What is the general most favorable performance street pad? Stoptec?
          '91 e30 325i - sold
          '09 e91 328i - sold
          • digger
            • Nov 2005
            • 6199
            OEM textar and jurid work great on the street and this is the brand what you get from the dealer if you are ok with paying a premium but they are available elsewhere if you look around in the aftermarket world. they do dust alot.
            given the brakes are slightly important i put up with the dust and wash the wheels occasionally....thats a decent tradeoff to me. its not hard to point a pressure washer at the wheels every now and then...
            if you plan on doing the occasional track days or similar then it is a fair enough to get a different pad as a tradeoff that copes with temperature better but does not bite quite as nicely as the above when stone cold.
            not until you bleed the stock brakes, and new pads/disc do you realise actually they arent that bad.
