Parts required for rear bearing/bushings
  • mathillois
    • Sep 2012
    • 71
    Hey r3v,
    I'm looking to takle the rear end by replacing my bearings and bushings.
    I was wondering what extra parts ill need to complete the job correctly. Let me know.
    Marc
  • lambo
    Captain Scene Points
    • 10953
    - 2X axle nuts
    - 2X axle nut lock plates
    - 2X wheel bearing circlip (if you feel like it)
    - rear brake lines (there should be 4 soft hoses) <-- I'd recommend doing this because it;s a BITCH with the subframe in the car.
    That's all I can think of.
    • uturn
      • Dec 2010
      • 1007
      Get an alignment to see if you need to install adj. rtab.
      • jalopi
        • 2370
        Convert to diff studs while you're at it. Also, in addition to the brake softlines I'd do the hardlines too - chances are after 20+ years the coated lines have finally started to rust/corrode.
        • rcsoundn1
          • Nov 2012
          • 3361
          bumping an older thread, as i am doing this now. How has everone taken the wheel bearing out of the rear arms, I assume i need a hub puller?
          • jalopi
            • 2370
            They're stuck in there real good. You'll need snap ring pliers to get the clip out and a press (or a wheel bearing tool) to get em out/in
            • Som
              • Jan 2014
              • 126
              I bought these to make it easy. You don't *need* them, as you can fashion your own pullers with the right size pieces of metal/threaded rod/bolts. But if you're looking for the lazy man's way out:
              For removing the bearing/outer race from the trailing arm:
              http://www.harborfreight.com/fwd-fro...ers-66829.html
              For removing the inner race that will be stuck to the flange:
              http://www.harborfreight.com/bearing...set-93980.html
              Som
              • e30_302
                • Sep 2013
                • 453
                The HF bearing puller makes it easy, but the threaded rod it comes with is junk. After you get it, take it to Lowes/HD/a hardware store and buy a real piece of threaded rod about the same size (and a few nuts to match). Use an impact gun if you have one.
                • mrob
                  • Sep 2016
                  • 21
                  These links are 404 not found. Could someone confirm that one or both of these are the right tools?
                  Bearing puller set with slide hammer
                  http://www.harborfreight.com/slide-h...-pc-62601.html
                  Bearing separator and puller
                  http://www.harborfreight.com/bearing...set-62593.html
                  Thanks in advance.
                  Som
                  • noid
                    • 1537
                    Change the brake backing plates while your in there.
                    SIR B90 BMW if you want to use the "right" tool for the job.
                    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                    Your resource to tools and tips: www.rtstools.com
                    • RainRider
                      • Aug 2014
                      • 362
                      Thanks in advance.
                      I believe he meant this... http://www.harborfreight.com/front-w...ers-63260.html
                      I use this for a lot of different jobs too. Pulls the rear bearings super easy.
                      • mrob
                        • Sep 2016
                        • 21
                        Thanks, RainRider. Which parts of this set do you use for the rear bearings?
                        • mrob
                          • Sep 2016
                          • 21
                          Thanks, noid!
                          • RainRider
                            • Aug 2014
                            • 362
                            Watch this video. https://youtu.be/D4PK1jXhppE
                            If you have a dremel tool with a cutoff wheel you won't need the bearing splitter tool. Just cut the bearing race enough to whack it with a chisel in the cut. You'll see.
