Subframe bracket install
  • blatant
    • Jul 2011
    • 96
    Hi all,
    Finishing up my swap with replacing the rtabs + subframe bushings. I have installed the subframe bushings and the associated 22mm nut with bracket. I am able to get one 6 mm Allen head bolt closest to the front of the engine in but I cannot get the second one in.
    I tried manipulating the bracket, trying to get the aft most one in first, all with no luck. I would appreciate any suggestions on how to install both of them verse just the one.
    I am using the akg 75d red bushings if that makes a difference.
    Thanks for the help.
  • blatant
    • Jul 2011
    • 96
    [ATTACH]87823[/ATTACH]
    • 36brua
      • 689
      send pics to AKG ask them if you installed bushings correctly
      My CA legal M60 swap
      The happening in our garage
      • jeffnhiscars
        • Jun 2011
        • 6011
        Loosen the 22mm nut so you have enough play to get the Allen bolts snug.
        Alice the Time Capsule
        • blatant
          • Jul 2011
          • 96
          I tried loosening the 22mm nut, but didn't have any luck. I'll send AKG an email.
          • SmokeE30
            • 1730
            iirc if the bushing is upside down or not all the way up inside it can do that.
            Shawn @ Bimmerbuddies
            Bimmerbuddies LLC
            717-388-1256
            2971a Roundtop Rd, Middletown PA 17057
            bimmerbuddiesllc@gmail.com
            • blatant
              • Jul 2011
              • 96
              I think it may not be all the way up. AKG got back to me and told me to jack the subframe all the way up, install the 2 fasteners and then the 22mm nut last. I'll double check to see if the subframe is all the way up, but I feel the picture posted shows it is.
