Rear wheel bearings carnage and a question, and a crap mechanic
  • rcsoundn1
    • Nov 2012
    • 3361
    So,i just took my rear trailing arms to get the bearings pressed in and the hubs and dust shields installed. The following is the "Professional carnage" please weigh in on if you think the new bearings are "Within spec" as the mechanic said or not.
    He cut the dust shields, mangled them with pliers, then painted them so it looked "ok". Am I wrong here or what? Click the first pic for video
  • noid
    • 1537
    Fuck that, that is some significant wobble you have in the bearing/hub. Cut the dust shield? Lol.
    Please post the name of the shop that charged you money for this atrocity of a job.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • rcsoundn1
      • Nov 2012
      • 3361
      FB page-https://www.facebook.com/pages/Zeus-Automotive-Repair/362990750444339?sk=timeline
      web page
      Enjoy our exceptional auto repair services in Loganville, GA. Our highly skilled certified technicians specialize in transmission and engine repair.
      • rcsoundn1
        • Nov 2012
        • 3361
        Name is Zeus auto. Guy was real mean about it all, and as he walked away he said, "this is why I dont do this for you people."
        • LJ851
          • 7919
          The bearing is not "normal" until the axle is through it and torqued. It will be loose until then. I can't comment on if it was installed properly, but i guess he pressed the hub back in the new bearing and forgot to put the dust shield on first. To remove the hub would damage/destroy the new bearing so he cut the shield to install it.
          Lorin
          The M30 is God's engine.
          • Todd Black 88
            • Oct 2007
            • 3449
            Wow!
            Cut the dust shield. Wow. I don't even....
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • rcsoundn1
              • Nov 2012
              • 3361
              LJ851 that is my real question. How much play should it have? And now my dust shield is wrecked. Im worried the ebrake set up will not work well after what he did.
              • LJ851
                • 7919
                When the axle is through and torqued there should be zero play.
                Lorin
                • Poorboyz
                  • May 2012
                  • 2117
                  I would not be happy with that...AT ALL. I would Def make him buy new bearings and dust shields...and don't let him do the job again.
                  Sent from my 831C using Tapatalk
                  Rebuilding since 07/06/2016
                  Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                  Poorboyz Feedback Thread
                  • rcsoundn1
                    • Nov 2012
                    • 3361
                    Which I do believe, but my concern was that the old bearing with 100k on them had less play, almost none.
                    • rcsoundn1
                      • Nov 2012
                      • 3361
                      only way to do that is sue him now. he has my 250 with labor and part that i supplied.
                      • Poorboyz
                        • May 2012
                        • 2117
                        Mistake #1 is that you paid for it. Sorry you're in this position.
                        • rcsoundn1
                          • Nov 2012
                          • 3361
                          You are correct, I did pay BEFORE I saw the parts. As soon as I asked to see the owner, they knew what was up, because initially they said he wasn't around. SURPRISE he was right there. and his office worker was all shady and acted worried.
                          • LJ851
                            • 7919
                            The bearing is a double row unit and there are two inner races, one for each row of balls. The two inner races can move all around (play) and need to be torqued together to properly assess the feel of the bearing. Your old bearing prob felt better because it had already been torqued together and the press fit of the hub was holding it there. I don't see an axle in any of the pictures, have you installed it yet?
                            None of this matters if you are going to replace the shield, you will have to replace the bearing after the hub comes out with an inner race stuck to it like it usually does.
                            Lorin
                            • rcsoundn1
                              • Nov 2012
                              • 3361
                              LJ I do appreciate all you say. I have read many of your threads and respect your opinions. I just got the arms back today and was very turned off by the play and the cuts in the dust shields. I was very hesitant to install the arms because of all the play, and shoddy dust shield work.
