Best Steel Braided Brake Lines
  • E30NJ
    • Aug 2013
    • 921
    Hi, I put my car up on the lift the other day and I put on my winter tires and did a little winter prep. However, I inspected the brake lines which are fine, but the rubber lines running to the calipers are cracking and I'd rather replace them with braided stainless steel ones because I want better braking and I don't want to have to replace them. ever. Anybody have experience and any suggestions on what you use/liked. 1987 325is 5 Speed BonzitBeigeBetallic
    Thanks guys
  • SkiFree
    • Jun 2011
    • 2766
    Forgive me but that's like asking what's your favorite Chocolate Chip Cookie.
    This link should be more than enough to suffice though. http://www.r3vlimited.com/board/showthread.php?t=240073
    ADAMS Autosport
    • E30NJ
      • Aug 2013
      • 921
      Haha good way to put it. What kind did you buy though? I'm thinking of the turner motorsport ones
        • 37833
        I've used the IE lines more than a few times and very happy with the quality.
        Grover Beach, California
        BimmerHeads.com
        • RedReplicant
          • Oct 2009
          • 270
          I have the BMA ones for $72. Work fine.
          91 318is - Gone
          16 VW GTI
          07 Aprilia Tuono
          • berlow94
            • Jan 2013
            • 1063
            Rogue engineering all the way. Every line is made to order and not just "DOT-approved" but DOT tested. Every single line comes a little wet because every single one is pressure tested before it's sent out.
            The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
            • efficient
              • Feb 2012
              • 3312
              Originally posted by redreplicant
              i have the bma ones for $72. Work fine.
              x2
              • NorseMan
                • Oct 2014
                • 12
                ECS is having a kiler sale right now. I've been researching all the sources for brake kits and decided on their kit due to components and price. I bought the 4 wheel kits with rotors, pads, wear sensors, rotor set screws for $186! I added their stainless steel brake lines too. Heck of a deal. See http://www.ecstuning.com/BMW-E30-318...Kit/ES2731604/ .
                • SkiFree
                  • Jun 2011
                  • 2766
                  NorseMan,
                  With all due respect to ECS, they are not US-made lines, nor are they DOT-approved. As mentioned in the link, the marketing-speak can get tricky.
                  ADAMS Autosport
                  • cdeason
                    • Nov 2011
                    • 88
                    SS Brake Lines
                    When I was searching for my M3, the only brake lines that were DOT approved, DOT tested and each line inspected/tested were StopTech, that may be different for regular E30's
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      i have the BMA ones ready to go on my car when i put it back together.
                      IG: @mitchlikesbikes
                      • SkiFree
                        • Jun 2011
                        • 2766
                        See link above. There is a list of DOT-approved line suppliers. Stoptech uses the same manufacturer as a number of others on the list.
                        ADAMS Autosport
                        • NorseMan
                          • Oct 2014
                          • 12
                          Originally posted by SkiFree
                          NorseMan,
                          They are approved. See http://www.ecstuning.com/BMW-E30-318...ines/ES252829/
                          • SkiFree
                            • Jun 2011
                            • 2766
                            from the link at the top......
                            You'll find that some seller's will try to say something like "Made to meet 'stringent' DOT standards", this should be a Big Red Flag. It needs to explicitly say 'DOT Approved'.
                            From the ECS website link you gave: "DOT-compliant 6 line kit" " They are manufactured to comply with DOT (U.S. Department of Transportation) FMVSS 106 standards."
                            So, no, they are not DOT-Approved. Just because they are "compliant" does NOT mean they are actually street-legal dot-approved. As I mentioned, some suppliers get pretty tricky in their verbiage in order to offer a cheaper substitute.
                            ADAMS Autosport
                            • berlow94
                              • Jan 2013
                              • 1063
                              Like I said, Rogue are the only lines on the market (to my knowledge) that are actually tested. Not just "compliant" or "approved"
