Replacing F+R pads and rotors…
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    most blanks come with the bolts. my 28 dollar brembo blanks came with new hardware.
    • mrsleeve
      • Mar 2005
      • 16386
      Originally posted by formula driver
      Get new rotor alignment bolts and be carefull taking them off. Im doing brakes right now.
      yes I had to drill the heads off mine just to get the rotor off so I could get the vicescrips and het in the rest of the bolt.
      Also when you put the new bolts in, antisize is your friend
      Originally posted by Fusion
      William Pitt-
      • ptownTSI
        • Jun 2005
        • 1265
        one thing i dont like about the bentley is it will say things like "use a puller to remove the hub"...well what kind of puller, what size...etc.
        • Spencer
          • 767
          "one thing i dont like about the bentley is it will say things like "use a puller to remove the hub"...well what kind of puller, what size...etc."
          I agree!
          Brakes were VERY simple. You don't even need the bentley really.
          -Spencer
          • KangamangusDriver
            • Aug 2005
            • 1870
            Use anti-seize on the bolts
            • browntown
              • Jun 2004
              • 3524
              might as well rebuild your calipers. Rebuild kits are cheap, see pelicanparts or call bma. If you dont have one, get a pressure bleeder. I like speedvalves too. Take a look at your ebrake while your at it, could use some new shoes. Get some nice DOT 4 like ate.
              • arsevader
                • May 2005
                • 1025
                Unlikely that parking brake shoes are worn unless you've been driving with the handbrake on. More likely that the hardware is corrroded to shit.
