Brake fluid leaking just replace Grommet
  • Kevinl
    • Oct 2012
    • 897
    So I had to add brake fluid to the e30 and figured brakes were getting worn but its low again I think its leaking where the master cylinder meets the reservoir considering a new master with reservoir is $300 can I just replace the gromets for $5 instead
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • LJ851
    • 7919
    If it is leaking because of worn out grommets, then replacing the grommets is a fantastic idea.
    Lorin
    The M30 is God's engine.
    • reelizmpro
      • 9558
      Yup, had the same issue before. The grommets are easily changed.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • iansane
        • 1343
        I would replace or rebuild the master. That grommet is not meant to seal fluid inside the master. If there is fluid there it's because the fluid is leaking past piston/seal inside the master.
        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • 37833
          He said it's leaking where the master meets the reservoir. This is not a sign of a bad master cylinder at all. It's a sign of bad grommets. Easy and cheap fix. If there was brake fluid going in to the booster I'd be worried though.
          Grover Beach, California
          BimmerHeads.com
          • iansane
            • 1343
            D'oh, ready comprehension owns me. I was thinking about booster deletes and the seal between master/Booster.
