Brake booster question
  • PumpdUpKicks
    • Nov 2012
    • 140
    My E30 sat for over a year with a mess of problems, and now its time to tackle my brakes issue.
    My brake pedal has no pressure against it while im stepping on it, and not until the pedal is fully pressed to the floor will the brakes eventually work.
    My first question is does the brake booster keep constant vacuum? Im not 100% sure i have asking the question correctly, but i was attempting to seafoam my car through the vacuum line coming off the brake booster, the hose that connects booster to the check valve was a PITA, so i just disconnected the rubber hose, and put a cone with flex hose to be able to pour seafoam slowly into it, but the brake booster was not creating any vacuum.
    so again, if the brake booster isnt creating a vacuum, could that be the cause of the brake pedal being soft?
  • Todd Black 88
    • Oct 2007
    • 3449
    Without booster vacuum, it would feel how it feels when he car is off. Hard.
    Your soft pedal is probably a bad m/c
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • PumpdUpKicks
      • Nov 2012
      • 140
      ah ok thanks, now should there be vacuum coming from the booster when i have the hose off? for when i am adding seafoam.
        • 37832
        The booster doesn't make the vacuum. The engine does.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
