rubber and/or poly subframe TAB
  • jrobie79
    • Mar 2006
    • 2526
    Recently went to get my car aligned (rear weld on kit) and couldn't because the outboard (toe) adjusters were seized.
    Dropped my subframe and discovered the TABs are junk - I believe they were IE, not positive though. My subframe bushings are IE and are perfectly fine.
    My question is - if I go stock rubber TABs should I swap the subframe bushings to rubber? Just looking for input, I'd like to not replace the subframe ones if I can, for money reasons
    1991 318i ---- 308K - retired
  • agent
    Vice Grand Pubaa
    • 7960
    When I was shopping for bushings and RTABs, Cherie at Harrison Motorsports said they always recommend the hardest grade poly for RTABS on a car that will be tracked at all, regardless of which subframe bushing you choose. That said, I was looking at the various poly offerings and wasn't planning to put rubber back in.
    FWIW I ended up going with 95A subframe and diff, and 75D RTABs - AKGs for all.
    Originally posted by kronus
    • jrobie79
      • Mar 2006
      • 2526
      its 100% DD...that said I know it would be soo much easier to go new poly, but they are more $$
      I swapped it all to poly a several years back because I was young and I guess some say dumb...I didn't notice it being too harsh from stock, but then again when I swapped to poly from stock the stock were beat to shit, so I guess I didn't have any real expectations or knowledge of what new OEM felt like
      • agent
        Vice Grand Pubaa
        • 7960
        Yeah, for a 100% DD car I'd put rubber back in.
        • estoguy
          • May 2013
          • 1087
          Rubber will be fine for a DD and not that hard to swap, if you had to do it again.
          For the install, you just need to lube them with soapy water. I pulled the whole frame out. I ran a wire brush on a drill to make sure the insides of the housings were nice and clean. The subframe bushings went in with a mallet. The RTABs with a homemade tool... check out E30zone wiki. There is a homemade tool shown there for RTABs. When you pull rubber RTABs, you just need to heat the housing a bit with a torch and use the homemade tool... come out nicely.
          I noticed a difference right away having good bushings.
          Don't forget to tighten the RTAB bolts with the rear wheels on the ground or ramps.
          Estoguy
          • kronus
            • Apr 2008
            • 13032
            I read somewhere at some point that if you have eccentric adjusters you should use OE rubber TABs or they will bind.
            A guy on e30tech machined some monoball TABs to address this problem but I haven't seen him around in a few years.
            cars beep boop
            • jrobie79
              • Mar 2006
              • 2526
              I had the IE's with the eccentric adjusters, and they never seemed to bind...the TA dropped fairly easily when I unbolted the shock, but I ordered rubber anyways, gonna keep the subframe bushings poly because I'm cheap and I haven't had any problems with them
              • gespinal0301
                • Jan 2011
                • 317
                I recently updated my entire suspension and rear subframe. I decided to go with poly bushings and while it is a wayyyyy better experience the vibration is extremely faint/hardly noticeable. Everything on my car is poly from the CAB to the motor and tranny mounts, even the guibo is. My car is a DD as well and the ride is very similar to stock.
                To get the TABs out I followed this principle: https://www.youtube.com/watch?v=6WEzP5OEzvQ took about 2 minutes to set up and another minute to get it out. It helps to heat up the frame with a torch to help them slide out
                My Daily Driven 318is
                • 2mAn
                  SeƱior Mod
                  • 21061
                  I used the "softer" Poly from AKG and the ride is fine, its the noise that is annoying me
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
