Brake sizes
  • CH9
    • Jan 2016
    • 11
    Brake sizes
    Ordered new disks seems they're 260mmx22mm my carrier is too small for them is there a way to keep the larger disks as I may not be able to send them back or would I just need to get 260x10 which is the other size I think.
    Any help would be great!
    Thanks,
  • CH9
    • Jan 2016
    • 11
    Any ideas? Could I just get the 325i calipers?
    This is for the front btw.
    • TobyB
      • 5297
      Yes, if you have the soild rotors, you should be able to get vented
      calipers, carriers, and bolt it all together. But do check
      the mounts on the struts- you probably have the small tubes,
      and I won't swear that they have the same mounting pattern
      as the larger 6 cyl tubes.
      (but I bet they do)
      You'll like it.
      t
      • CH9
        • Jan 2016
        • 11
        I do have the 45mm struts. Will look into getting the calipers etc.
        Thanks for the help :)
