ABS unit plumbing? CLOSED
  • R3Z3N
    • Jan 2011
    • 3056
    Curious if anyone has info on which inlets on the ABS pump are for front and rear?
    I had a proportioning valve installed by a shop years ago as I didn't have time, and recently am installing an S54, along with dual MC setup and bias bar, and the shop may have installed the valve on the wrong line. :rippedoff:
    Since I am in there, just double checking work.
    Heres the setup so far, but don't look at which line is Front or Rear as for my prior S52 swap they may have been swapped anyway....
  • R3Z3N
    • Jan 2011
    • 3056
    Figured it out. I'll update later.
    • FredK
      • 14762
      As you may have figured out, the port labeled "h" is for "hinten", which is for the rear circuit, and "v" for "vorne", which is for the front circuit. Does Lee's kit change the leverage ratio for the pedal? Looks awesome.
      • R3Z3N
        • Jan 2011
        • 3056
        Yes, you have a choice of 6:1 and 7:1. Of course choose masters as needed/desired along with fine tuning the adjustment. Currently using 5/8s masters and 7:1 ratio. I believe I should be close to what I want with E36 M3 fronts and Massives Wilwood rear kit for the 318ti. Will be switching to Wilwood fronts after engine swap, but I assume one of the masters will need to change then.
