E30 braking issue
  • Brice325i
    • Jul 2015
    • 19
    E30 braking issue
    I just started experiencing an abnormality in my 87 325i when I brake. The pedal seems to want to go all the way down to the floor sometimes. Other times it acts like it has for years. I checked the brake fluid reservoir and it is full. No puddles underneath the car either. I did however, find that a black liquid underneath the rear passenger side near that tire seems to have sprayed. It's still wet. HELP!
  • roguetoaster
    Biggus Tippus
    • 7830
    If it's really not leaking (do check that) then I'd suspect that the master cylinder has given up. However, it is possible that the axle is tossing grease instead of the brake system.
    Is the pedal sinking to the floor rapidly or just steadily dropping as you apply constant pressure?
    • TobyB
      • 5297
      master cylinder
      and/or a leak. Figure out if your mystery fluid's brake fluid...
      t
      • Brice325i
        • Jul 2015
        • 19
        Gradually going to the floor
        • e30onBBSs
          • Dec 2014
          • 1347
          Check everywhere not just MC if you haven't
          BMW tech
          Umass Amherst
          05 wrx sti
          • 101
            • Jul 2011
            • 764
            If the fluid reservoir is staying full and there's no visible leak at any of the lines or calipers, then I concur - the master cylinder is the likely issue.
            101
            The E30 collection:
            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
            1987 325is - Delphin / Black Sport (son #3's)
            1987 325i Convertible - Triple Black
            1989 325iX Coupe - Diamondschwarz / Black Comfort
            1990 325iX Coupe - Sterling Silver / Grey Sport
            1981 Fiat 124 Spider 2000 - Green / Tan
            1998 Volvo V70 GLT - White / Tan
            1998 Volvo S70 T5 manual - White / Taupe
            2001 Ford Windstar - Silver / Grey (parts hauler)
            2006 Lexus GX470 - White / Tan (tow rig)
