Are e36 M3 brakes overkill on an e30
  • greg1333
    • Nov 2004
    • 127
    I am doing a 5lug conversion to a 24v e30. the car will be used for weekend fun and autocross.
    My question is, does it need the larger e36 M3 brakes up front or will the non-M e36 front brakes be fine.
    The reason I ask is for wheel and tire selection. M3 brakes will require the use of 17" wheels while non-M conversions will allow for 15" wheels.
    I have both sets of spindles in hand...its just which one ends up on the car.
    Thanks in advance
  • Eric
    • 5142
    not overkill
    • greg1333
      • Nov 2004
      • 127
      I guess the correct question should have been; Are non-M brakes sufficient?
      • whodwho
        • Jun 2008
        • 1547
        Since you have the parts I would check the fit on the rims. I have E46 M3 brakes(325mm Rotor) under 16" rims(E38 style 5), I would think E36 M3 should fit fine
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • b-rad
          • Nov 2015
          • 232
          E30/1987 325is / S50 Swapped
          Trying to make the same decision. I have 16" Style 5 with 88 M3 Suspension/Brakes now.
          Want to goto BBK, but would like to keep the 16" Rim
          Massive does not sell the kit that would work.
          Is the IE, basically the same?
          Since I have the 5 lug, the kit's are somewhat limited.
          Thoughts?
          1987 BMW 325is,(M3 S50 Swapped)-Current
          2010 FJ Cruiser, aka E30 Support Vehicle-(Daily)
          2008 Scion xB Lowered
          2001 BMW 325i
          1995 BMW 318ti
          1966 Ford Mustang Coupe
          1965 Ford Mustang Coupe
          My Thread
          • greg1333
            • Nov 2004
            • 127
            My concern is more about performance than appearance.
            • reelizmpro
              • 9543
              Nice factory upgrade. I just don't like the change to E36 offset in front.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • FredK
                • 14761
                I believe using the E36 M3 parts will get you better front suspension geometry. What rear brakes are you planning on using? I think you'll bias the braking to the front by a decent amount if you use 318Ti rear brakes, which makes the car feel like it's braking harder since the car will pitch forward more, but your stopping distances may ultimately be lengthened by a small amount.
                As for the E30 M3 IE BBK, it will likely be about the same as the formerly available 300x32mm Massive kit, so long as the pistons are sized for the application.
                • greg1333
                  • Nov 2004
                  • 127
                  Rear brakes are e30 m3
                  • FredK
                    • 14761
                    That's not too bad, then. E30 M3 has 38mm rear pistons. If you want to get slightly better braking you can swap out the calipers with 40mm calipers from an E34 540iT.
                    • Eric
                      • 5142
                      Good call Fred. You can fit a bunch of 16" wheels on e36 M3 front brakes, just takes a test fit!
                      • greg1333
                        • Nov 2004
                        • 127
                        So from what I have seen on the forums, the e46 330i calipers and rotors bolt up to the non-M e36 spindles giving the same diameter rotor as the e36M brakes....
                        I understand the rotor is slightly thinner rotor and the piston is little smaller, but it would allow me to more easily upgrade from the 286mm to the 325mm setup.
                        Has anyone here done this?
