BBK: www.300mm.de
Surprised?
It's no big secret. There about 6-8 BBK combo's commonly used for the E30 and they all are variations of this approach. I have posted several tweaks involving fab work and usually get a reponse of " Why don't you just buy "such and such"? I've also been cheaped out for even mentioning anything other than new calipers.
You are paying for the design, fab work, certification, and safety. As has been pointed out to me several times, not everyone has access to a machine shop or the know how to do these things. And the scariest thought of all is do you want to be the test car for someone else's QA program with your front brakes?.
Now it's time for someone to say it's not rocket science and they can..........
The price is good and in hour or two you're back on the road!Last edited by 1991 318is; 08-27-2006, 10:43 AM.
It is not a brain science or rock3t surgery!
I will build one of these setups myself and I am guestimating $250-350 cost of the project including junk yard parts.
As I said earlier: I wish I could make out the numbers on that drawing as it would save me a few hours of r&d.
Is investing a few hours worth saving 1/2 a grand?
Need I answer?
Problem for me rigth now is that I am in the process of building my 4x4 and simply have no time, mental focus and budget to invest in the bimmer rigth now.
BTW:
I will post the pics of my other project when it's done in the Off topic lounge, and yes, there will be a BMW content in it
... but I will keep that a little secret for now.
(.Y.) R cool.
Falco rocks!Comment
BTW, I went to ATE's site and found specs on all of their rotors. The 2003 Audi TT (P/N D930) uses a 312mmX25mm disk, with a heigth of 35mm.
The E30 rotors have a height of 36mm.
I found the ATE "PowerDisk" (or whatever they call them) for $178/pr. That would look really hot...and for me, as long as they work as well as stock, looks are the ONLY reason I am doing this.
Yup, "rice" brakes.
LukeComment
If you go check out Tito's site, you can see they are re-drilled, and the center bore punched out 1mm.
The translated link is at the start of this thread.
He shows 17" Alpina Kopi's over the 312mm setup. Sweet and hot like good mustard, yO!
LukeComment
U mean you found the powerdisc for the audi TT or the stock powerdisc for the e30. Afaik the e30 ones are NLA.?BTW, I went to ATE's site and found specs on all of their rotors. The 2003 Audi TT (P/N D930) uses a 312mmX25mm disk, with a heigth of 35mm.
Yup, "rice" brakes.
LukeComment
i was going to say they were audi tt rotors, but i am WWWAAAAYYYY too late. cay you still use the stock flex lines (like if you already have ss lines are you going to have to get custom ones made up after the install?)seien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
You know, he doesn't mention lines at all in his site, so I have no clue.
Seems like it might be stock fitment, since the caliper only moves an inch or so.
I have SS lines, I don't wann hafta replace them.
LukeComment
if you need custom lines made up i can get them made up for around $30ish a pair ( i would need to check the price since it had been a while, and they are not DOT approved) i was working out a similar set up using tt rotors and either viper front or boxter front calipers (i have a pair of both). i was going to try the same thing on my A2 jetta (that's why i got the tt rotors) with either the tt's or 996 front rotors (heavy and i would need to make a custom hub). since a 280mm 4 lug corrado rotor can be fitted to an e-30, the tt would be the next logical step up in dia. stock legnth lines would be nice though.seien Sie größer, als Sie erscheinen
Would such a combo keep from creating major brake bias?
Although braking systems are faily foreign to me I do know that keeping proper balance is the key to a fast stopping car. I've been reading through the tech articles on the Stoptech site which are very informative."We've stumbled along for a while, trying to run a new civilization in old ways, but we've got to start to make this world over." -Thomas Edison, 1912Comment
