Spun Out and Hit Curb, Rear Wheel Now "Cambered Out"
  • savikbmw
    • Dec 2016
    • 9
    I was driving last night and the road was wet, and I was going a corner a little too fast for my bald tires and I spun out. I hit a curb that was about 4 inches high with my back wheel. I completely destroyed the lip of the wheel, but I changed the spare on and I drove home. As far as I could tell in the dark, everything seemed fine other than that.
    The car didn't drive different than normal, but I did notice that the steering wheel was turned about 10° to the right when I was driving straight. Now that it's light out, I can see that the reason for that is that my left rear wheel looks like it was pushed in on the bottom. I just jacked up the car and I can't even see anything bent in the suspension, and it looks just like the other side. I know you can't adjust that with an alignment, but I guess I need to replace some parts of my suspension. What could be broken?
    Pics:
    I can take pictures of the suspension as well if that could help.
  • nrubenstein
    • 3148
    Easy fix. Just replace the trailing arm.
    And buy new tires.
    And ideally replace all the bushings in the rear suspension while you are at it.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • savikbmw
      • Dec 2016
      • 9
      And buy new tires.
      Thanks.
      I was planning on getting new tires and suspension pieces anyway.
      I guess it could be much worse.
      • Powling
        • Jan 2015
        • 1291
        Originally posted by savikbmw
        Thanks.
        Definitely could be much worse. No one was hurt so you should be happy about that.
        But I second the new tires. RWD light cars in the rain with bald tires is just asking for someone to get hurt...especially when you're NOT trying to get sideways on purpose, haha.
        Steve • Toronto
        1991 318is • Brillantrot
        Build Thread
        • Shock(/\)ave
          • 350
          I've lost count how many cars I've seen totaled by driving too fast on bald tires. You were very, very lucky.
          Don't cheap out on tires people!
          • rturbo 930
            • Dec 2005
            • 2629
            My tires aren't bald, they just aren't very good. Definitely a few times my E30 has surprised me in the rain back when I DD'd it.
              The trailing arm on that side is probably bent. But the incident could have also damaged the subframe. Replace the trailing arm, then have the camber checked to find out if the subframe is bent.
              • savikbmw
                • Dec 2016
                • 9
                I'm going to the Pull-A-Part to grab the trailing arm off of the E30 they have there. Do you think I'd be best getting the whole subframe too?
                  Having the whole subframe might be a good thing. But, as is likely, the subframe bushing sleeves could be corroded and stuck. Making the job a PITA. You will have to decide if it is worth the effort.
                  Not mentioned earlier is the need for new trailing arm bushings. And there is the possibility of bad bearings that will need to be replaced.
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5606
                    Just replace that trailing arm and get the car up on an alignment machine to see if anything else back there got effed up.
                    bad tires, open diff, wet road and an e30 is like staring the grim reaper in the face
                    • savikbmw
                      • Dec 2016
                      • 9
                      I planned on buying the kit of all new bushings from ECS tuning anyway. My diff mount is ruined so I was going to replace that while I was down there too.
                      Im probably just going to cut the things that are corroded at the junk yard and then deal with getting the old stuff out of the trailing arm once I get home.
                      Also, I have an LSD, I just didn't know how to control it and by the time I realized what was even happening I was on the sidewalk.
                      • Powling
                        • Jan 2015
                        • 1291
                        "Bald..."Not Good"...
                        ...its the same thing. In both cases, you need to replace them. Period.
                        Steve • Toronto
                        Build Thread
                        • rturbo 930
                          • Dec 2005
                          • 2629
                          No, I mean they are cheap tires. Not the same thing.
                          I was planning on getting new wheels and tires, but I don't drive it anymore so it hasn't happened.
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            No, its like staring your avatar in the face
                            My previous build (currently E30-less)
                            http://www.r3vlimited.com/board/showthread.php?t=170390
                            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5606
