Front end suspension chatter
  • Sail Boat
    • Oct 2016
    • 143
    Hi all,
    '91 325i with just under 30,000mi
    When I drive over road imperfections such as shallow potholes and raised bits of asphalt, the passenger side of my suspension makes a horrendous chatter. Its a precise and quick rattling noise, like very muffled metal-on-metal contact. At first, I thought it was the lower control arms, but the car is very stable and handles great otherwise - no shimmy on braking, no steering noises, etc. (I think those symptoms point to bas LCA's? lol)
    Shake test was inconclusive, everything is tight and seems solid.
    From my experience with suspension noises, it sounds like the sway bar is walking, perhaps the bar bushings are worn out?
    I'm pretty new to the e30, hopefully you all have experienced and solved a similar issue. Just trying to get ahead of the replace & pray game...
    1991 325i 4 dr Euro Spec, 5 Speed, 4.10 LSD, Slicktop
  • jeffnhiscars
    • Jun 2011
    • 6011
    Although they really don't "blow" check your strut mount.
    Alice the Time Capsule
    • Jb325is
      • 2137
      Check the gland nut that holds the struts into the strut housings
      - '88 m54 coupe
      <3
      • crash n' burn
        • Nov 2014
        • 211
        shock tower mount could also be worn, allowing movement and transmitting that popping noise through the chassis
        -89' 320iT, Brilliantrot
        -15' 320i, Glacier Silver Metallic
        • Sail Boat
          • Oct 2016
          • 143
          Thank you all for the feedback! I'll address the strut assembly before the anti-roll system. Or maybe at the same time...
