Fcab question
  • Gumby
    • 45
    Fcab question
    Should the control arm spin in the bushing?
    Sent from my iPad using Tapatalk
  • jeffnhiscars
    • Jun 2011
    • 6011
    Nope. If you have a rubber bushing it installs with a quick drying lube. The plan is to get the car back on its suspension so the bushing can set in its resting position. Otherwise it won't last long.
    Alice the Time Capsule
    • Gumby
      • 45
      They are solid Delrin if that makes any difference.
      • loki_
        • Sep 2013
        • 147
        It's not uncommon to drill into the lollipop and bushing and install a set screw when using offset delrin bushings.
        edit: I misread the question: CA in bushing instead of bushing in carrier. my bad lol
        • Gumby
          • 45
          Originally posted by loki_
          It's not uncommon to drill into the lollipop and bushing and install a set screw when using offset him bushings.
          The bushing itself isn't moving just the control arm
