Girling and ATE question....again
  • zaq123
    • Jul 2016
    • 1560
    Countless threads about it but they are very conflicting... mix/match ok, mix/match absolutely not ok and everything in between.
    I'm refreshing my brakes on my build and want to use NEW booster/master and rebuild my Girling calipers.
    Girling booster is NLA. Can I use ATE booster/ATE master combo with Girling calipers and my other existing brake parts (ABS pump etc).
    Thank you very much
  • kronus
    • Apr 2008
    • 13032
    yes, you can
    cars got girling and ate front calipers from the factory with no apparent rhyme or reason as to which kind was used, and the boosters/masters weren't changed to accommodate this.
    cars beep boop
